Move SHP to gdb and ArcView license (newbie frustration)!!!
12190
54
04-11-2012 07:58 AM
LucaMoiana
Hi there,
What I need to do is move all the files into an mxd to a newly created gdb, chechking prj, and update mxd reference.
I have ArcGIS 10 SP4, license ArcView
I studied a bit of Python and get familiar with basic, then I copied some written code and pasted all together, attached is the code.
My frustration is that i can???t even move my shp files to a created gdb, is that because of my ArcView license?
PLEASE PLEASE PLEASE HELP
# Import system modules
import arcpy
from arcpy import env
import os
# Set environment settings
env.workspace = "C:/Users/a391665/Documents/AAAAPERSONALE/rugareto"
# Execute CreateFileGDB
arcpy.CreateFileGDB_management("C:/park", "test4")
# Set local variables
outWorkspace = "c:/park/test4.gdb"
# Use ListFeatureClasses to generate a list of shapefiles in the
#  workspace shown above.
fcList = arcpy.ListFeatureClasses()
# Execute CopyFeatures for each input shapefile
for shapefile in fcList:
    # Determine the new output feature class path and name
    outFeatureClass = os.path.join(outWorkspace, shapefile.strip(".shp"))
    arcpy.CopyFeatures_management(shapefile, outFeatureClass)
MathewCoyle
Honored Contributor
What is your input coordinate system? You probably have to define a transformation.
LucaMoiana
As a test I'm suing an undefined and a GCS_Monte_Mario_Rome and GCS_WGS_1984; but ideally I would have 4 or 5 different prj as input and 2 different prj as output, these should be defined as paramters of the tool.
MathewCoyle
Honored Contributor
You cannot project an undefined coordinate system without defining the input coordinate system.
LucaMoiana
At the moment all layers are defined, but for the undefined I have:
            elif dsc.spatialReference.name == "Unknown":
                print os.path.join(workspace, fc, "UNKNOWN")
                fc_unkn = fc+'_unkn'
    arcpy.FeatureClassToGeodatabase_conversion(fc_unkn, outWorkspace)
    print os.path.join(workspace, fc_unkn, "imported in GDB")
MathewCoyle
Honored Contributor
Try doing a sample of each projection you want in ArcMap and it will give you a list of valid transformations. Then after you run it you can use the copy as python snippet as base to put in to each if case of your code.
