Move files from many folders to one with python
1040
09-01-2022 10:41 AM
LostInTheSauce
I've downloaded over 80 NAIP files and they all went into their own folders. I want to batch trim the imagery to the polygon that they came with so I can mosaic them all together without the null pixel borders. Is there a way to do this in python?
  • I assume I'll have to move all the files out of their own folder and into one common folder to make the script easier (or not?)
  • I will also have to figure out how to call them because they are numbered the same but named differently:
    • i.e. the image is called ortho_1-1_hn_s_fl133_2021_1.sid & the polygon is
      ortho_1-1_hn_fl133_2021_1
  • hoping to do this in the python window in Pro
Thanks for your help!
DannyMcVey
Esri Alum
What your planning sounds feasible with python. Others may have more detailed suggestions, but I want to point out that there is some related info and code samples here: Create lists of data—ArcGIS Pro | Documentation.
You won't necessarily need to move all the files into one common folder.
