Model Builder %value% add layer to map
1673
10-14-2011 06:36 AM
JamesMitchell
Hello,
Hopefully someone can help me.
I have a model that creates a buffer and then selects features that intersect the buffer.
I have set it up the shapefile that is created uses the buffer value as the shapefile name, however this shapefile will not add to the display. If i name this shapefile anything then it will add.
Is there a workaround for this issue?
Thank you for any help.
JamesMitchell
Hello,
This is beginning to bug me know. Is it possible to add a layer to the map that is created in model builder using the input buffer distance as the layer name?
Thank you
DuncanHornby
MVP Notable Contributor
James,
It would help us to help you if you post up your model.
Duncan
JakeSkinner
Esri Esteemed Contributor
Hi James,
I am assuming your shapefile begins with a number since it is based off of the buffer value.  This could be causing the problem.  When naming a shapefile/feature class, the name should not:
1.  Begin with a number
2.  Contain special characters (i.e. !, ?, #...)
3.  Contain spaces
JamesMitchell
Thanks for the reply.
In model builder there does not seem to be a way i can remove the space between the value and distance measure e.g. 10 Kilometers. I have tried to call the shapefile 'Buffer%Distance%' but this did not work either.
I have managed to add the layer using a Pythin script and MakeFeatureLayer_management
JordanDecker
Any chance you could post your Python script for this and/or explain how you did this in more detail?  Having same issue.
Thanks!
