Method to create unique values for two related attributes and make two variables
1743
05-16-2013 04:58 PM
CPoynter
Hi All,
The situation:
1 FC / 3 related columns / definitionQuery on one field has ' as part of field name for only some records which is causing problems
Column 1 = numeric code
Coumns 2 and 3 = text (both have troublesome ' when it comes to definition query)
I want to use Column 1 value that relates to Column 3, use Column 1 value for definition query to get around ' issues, but then need value of Column 3 for layout text element.
How do I get a unique listing of the related column 1 and 3 and then seperate their values for two subsequent operations?
I am thinking da.SearchCursor but unsure how to get fields in, make unique values and seperate values.
Thankyou in advance.
Using ArcGIS 10.1
Regards,
Craig
CPoynter
Code is working nicely that Arek supplied, but I think I need to clarify a bit more.
Column1 / Column3
1000 : PlaceA
1000 : PlaceA
1005 : PlaceA
1005 : PlaceA
1009 : PlaceB
1009 : PlaceB
After running the dictionary code I found similar named places in Column 3 but with different codes in Column 1. This was something I wasn't aware of until now. I will need to distinguish between same name using different codes.
I could not get the original definition query code to work:
'fldCode in (%s)' % map_dict[str(fldName)].join(', ')
so substituted with:
queryStr = "\"" + fldCode + "\" = " + str(row[1])
My complete code follows, but needs further work to achieve my desired output.
import arcpy  fc = r"D:\Locations.gdb\Places" fldName = "Place_Name" # Column 3 = row[0] fldCode = "Place_Code" # Column 1 = row[1]  map_dict = {}  with arcpy.da.SearchCursor(fc, (fldName, fldCode)) as collector:     uniqueValues = sorted(set(collector))     if not row[0] in map_dict.keys():       map_dict[row[0]] = []     if not row[1] in map_dict[row[0]]:       map_dict[row[0]].append(row[1])      queryStr = "\"" + fldCode + "\" = " + str(row[1])      mxd = arcpy.mapping.MapDocument(r"D:\Places.mxd")      elm = arcpy.mapping.ListLayoutElements(mxd, "TEXT_ELEMENT")[0]     elm.text = "Place: " + row[0]      df = arcpy.mapping.ListDataFrames(mxd, "Layers")[0]      for lyr in arcpy.mapping.ListLayers(mxd, "", df):              if lyr.name == "Places":                  if lyr.supports("DEFINITIONQUERY"):                     lyr.definitionQuery = queryStr      arcpy.RefreshActiveView()      arcpy.mapping.ExportToPDF(mxd, r"D:\Places\Output" + "\\" + row[0] + "_" + row[1] + ".pdf")   del mxd
I am trying to make map outputs that will only show places based on their unique code values.
I think I may have what I need now, but will notify forum if issues remaining.
Will investigate dictionaries further.
Regards,
Craig
ArkadiuszMatoszka
If I get it right, you want to get values from  Column 1 (Numeric) which corresponds to unique values from Column 3 (Text).
Assuming there can be more then one unique numeric values for each text value from Column 3 i I would suggest using dictionary with Column 3 value as key and list of Column 1 values as value. One important thing is that each value in Column 1 can correspond only to one value in Column 3.
Considering given assumptions code would be something like:
map_dict = {}
with arcpy.da.SearchCursor(fc, ['Colmun 3', 'Column 1'] as collector:
  for row in collector:
Now you can use
'Column1 in (%s)' % map_dict[Column3value].join(', ')
to build definition query, and Column3 value in other places.
Hope it will help.
Regards
Arek
CPoynter
Column1 / Column3
1000 : PlaceA
1000 : PlaceA
1005 : PlaceA
1005 : PlaceA
1009 : PlaceB
1009 : PlaceB
Regards,
Craig
CPoynter
Code works a treat. Arek's code for dictionaries was the clincher.
Regards,
Craig
