Matplotlib for Python scripting in ArcGIS 10 does not work
13437
21
06-29-2011 12:50 PM
wernerrolf
I use ArcGIS 10 and would like to run Matplotlib to create charts within a python script. Therefore I have installed
- numpy-1.6.1rc1-win32-superpack-python2.6.exe
- matplotlib-1.0.1.win32-py2.6.exe
as noted here: http://matplotlib.sourceforge.net/users/installing.html
If I test a script to check the installation like:
import numpy
arcpy.AddMessage("NUMPY Version " + numpy.__version__)
import matplotlib
arcpy.AddMessage("MATPLOTLIB Version " + matplotlib.__version__)
I get the following error:
Running script Script...
NUMPY Version 1.6.1rc1
<type 'exceptions.AttributeError'>: 'module' object has no attribute '__version__'
Failed to execute (Script).
Also the command
- import pylab as pl
leads to the error
<type 'exceptions.ImportError'>: No module named pylab
So even matplotlib is installed properly in the directory "site-packages" (see screenshot of directory structure attached) it does not work in ArcGIS.
By the way if I let it run in iPython (same installation) it works perfect.
What still needs to be done to get matplotlib work in ArcGIS 10?
Thanks
Werner
V_StuartFoote
Werner,
1) Looking at your install you didn't remove numpy-1.3, supposedly there are ArcPy DCOM elements hard coded against numpy-1.3, but having both releases present is probably not good.
Also, looking at the matplotlib site, only numpy-1.1 is required--did you need numpy-1.6 for some reason? Perhaps the numpy-1.3 will suffice for your plotting work and simplify your install.
The matplotlib Windows 32-bit installer at SourceForge seems to correctly install with the ESRI instance of Python 2.6.
That should get the matplotlib functional for you leaving your ESRI ArcGIS10.0 Python instance intact. I was able to do just this now including the PyReadline and IPython installers. All seem to work OK with just numpy-1.3.
If still having problems, you might want to look for any environment variables or .pth files that may need adjustment to the ESRI default Python installation at C:\Python26\ArcGIS10.0 that may be causing problems.
2) Alternatively, you may be able to load the Python 2.6 build of Python(X,Y)--uses numpy-1.6.0, and again there remains any dependencies of ArcPy on having a numpy-1.3 egg in place.
You would first need to uninstall the ESRI Python instance from Uninstall or Change a Program--saving a copy of the Desktop10.pth file from the site-packages directory to reuse in the new installation.  You'll then have to test what breaks in ArcPy without numpy-1.3.
Good luck.
Stuart
wernerrolf
Thanks first!
I wasn't aware that there were two versions of numpy running and deinstalled 1.6 again.
I now went completely through your 1st proposal:
So now I now have numpy 1.3 and the matplotlib Windows 32-bit installer that you recommended on my machine. Unfortunatly it still does not work. What confuses me is that numpy seem to work, it's more that matplotlib seem to have the problem i.e. pyplot that comes along with it.
I always get the warning: No module named pyplot
I also checked the pth file and have three variables in there:
C:\Programme\ArcGIS\Desktop10.0\bin
C:\Programme\ArcGIS\Desktop10.0\arcpy
C:\Programme\ArcGIS\Desktop10.0\ArcToolbox\Scripts
Do I need other in there?
At least so far this seem not to work for some reason.
Before I will try your second proposal I'm still looking for alternatives as I do have one of those campus licences that I'm only able to install at university and if I screw this up here I'll be in big mess as I cannot go there in next time and have to get my work done before that.
V_StuartFoote
Werner,
Any chance you just need to issue the call to pyplot as matplotlib.pyplot?
Those entries in your Desktop10.pth file look OK.
Your %PATH% variable should have a C:\Python26\ArcGIS10.0 entry, and python.exe and pythonw.exe should only be in that directory.
Also, have a look in the registry at this Key:
HKEY_LOCAL_MACHINE\SOFTWARE\Python\PythonCore\2.6\PythonPath
Note: would be SOFTWARE\Wow6432Node\Python on 64-bit OS.
The key's Default value should have a lib-tk value laid down by the matplotlib installer that matches ESRI's Python 2.6 instance. Something like this:
[INDENT]C:\Python26\ArcGIS10.0\Lib;C:\Python26\ArcGIS10.0\DLLs;C:\Python26\ArcGIS10.0\Lib\lib-tk
[/INDENT]
If it was not laid down in the same path, you'll need to uninstall matplotlib, and numpy packages. Then reinstall numpy-1.3.0 and matplotlib-1.0.1.
When the package installer GUIs run be sure to choose the C:\Python26\ArcGIS10.0 instance of Python.
Stuart
wernerrolf
The registry key is fine.
Sorry but I didn't get what you meant if I need to issue the call to pyplot as matplotlib.pyplot.
Furthermore where do I have to look if the %PATH% variable has a C:\Python26\ArcGIS10.0 entry?
What may also confuse is the fact, that if I run IPython any scripts with arcpy and matplotlib work totally fine, but not if I run the same script in ArcGIS or IDLE that comes along with its installation.
Thanks for your patience!
V_StuartFoote
Werner,
From a command prompt issue:
[INDENT]echo %PATH%
[/INDENT]From a regedit session browse to:
[INDENT]HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Session Manager\Environment[/INDENT]
Or probably best (because you can see both System and Current User values) select:[INDENT]Start --> Computer --> Properties (System Properties) --> Advanced System Settings (Advanced tab) --> Environment Variables
[/INDENT]
The Current User will have a Path -- just be sure if it has any Python related paths they do not conflict with the C:\Python26\ArcGIS10.0 location. And in the System Variables block that in the PATH listing, that C:\Python26\ArcGIS10.0 is the only listed Python--or at the least it must be the first listed.
Here is a sample pytplot script that should run displaying a Tcl/Tk plot from IDLE, PyWin32, IPython. It should run even in the ArcMap Python window (either enter each line or load it as a script).
import numpy as np
import matplotlib.pyplot as plt
x = np.arange(0, 5, 0.1);
y = np.sin(x)
plt.plot(x, y)
plt.show()
If you can get it to run in IDLE and the ArcMap Python window you've fixed any path or configuration issues.
Syntax of the packages in your code is another issue.
Stuart
wernerrolf
I have checked the path but need not to change anything.
The Path looked like:
C:\Python26\ArcGIS10.0\Lib\site-packages\PyQt4;%SystemRoot%\system32;%SystemRoot%;%SystemRoot%\System32\Wbem;
Your script example works at least in IDLE - for what kind of ever reason as others do not. But if I tart it within ArcMap I get the error:
<class '_tkinter.TclError'>: bad screen distance "640.0"
Failed to execute
Im wondering to give it up or suggest this questions to ask at the next ESRI User Conference.
Furthermore there seem to be a need of some serious improvements on the python interface of ArcGIS, as other matplotlib scripts that are working with python regularly don't work if lauchend in ArcMap.
Hopefully in next versions this will work more consistent.
Anyway thank you very much for your help!
V_StuartFoote
Werner,
With that PATH value you do not have an explicit path to the Python program and libraries.
IMHO to run Python from the command line and for proper functioning of many programs, an entry in the PATH allows you explicit control of the Python executable called. If you did have multiple versions of Python installed, i.e. Python(X, Y) as mentioned, you would control the active version by its position in the PATH.
Here is a sample System Variable Path from my Windows 7 64-bit test workstation--graphic device drivers, operating system, then Python with other applications further down the search path.
C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Python26\ArcGIS10.0;C:\Perl64\site\bin;C:\Perl64\bin;C:\Program Files (x86)\QuickTime\QTSystem;c:\HEGtools\HEG_Win\bin;C:\Program Files\AutoCAD Raster Design 2010\;C:\Program Files\MATLAB\R2011a\bin;C:\utils\trid;C:\FlexNet32
With C:\Python26\ArcGIS10.0 included, this allows one to issue a python or pythonw command or import an associated library under that path from any shell enabled application on the system.
I also have a PYTHONPATH System Variable that as an explicit location takes precedence over standard libarary locations or .PTH files--in this instance I've duplicated the ArcGIS Desktop10.pth values.
C:\Program Files (x86)\ArcGIS\Desktop10.0\bin;C:\Program Files (x86)\ArcGIS\Desktop10.0\arcpy;C:\Program Files (x86)\ArcGIS\Desktop10.0\ArcToolbox
The problem with the tkinter.TclError -- bad screen distance "640.0" may be related to your numerical locale setting. In German Windows the "," decimal mark causes some issues.
Found this as a work around, maybe it will help with matplotlib in general with ArcGIS.
import locale
locale.setlocale(locale.LC_NUMERIC, 'C')
here:
[INDENT]http://trac-hacks.org/ticket/1872
http://www.mail-archive.com/matplotlib-users@lists.sourceforge.net/msg21373.html.
http://old.nabble.com/%22bad-screen-distance%22-tkinter-error-with-German-locale-td31964358.html
[/INDENT]
Stuart
wernerrolf
Thanks once again, the numerical locale setting code works. And in deed its once agtain one step further. I also changed the path now, so that it now looks like:
Nevertheless the error No module named pylab still remains.
V_StuartFoote
Well it's progress 🙂
I believe that pylab is a module of the matplotlib site-package. Don't you first need to import matplotlib to be able to call a pylab function?
Or you might try the pylab calls explicitly, but that may leave you without some of the other matplotlib functions:
import matplotlib.pylab as pl
Stuart
