MapSeries Export to JPEG Issue
3009
8
09-12-2023 01:30 PM
ScoutStanley
Hi, I am having a hard time figuring out how to get my script to export the layout as .jpg. The purpose of the script is that it loops through table and creates new layout based on the row value and then exports that layout. The script works perfectly with exportToPDF, but I can't figure out how to get exportToJPEG to work. Any ideas???
print("\n\tExporting map to pdf...")
        finallocationwithPIN = path.join(finallocation, PIN)
        if path.exists(finallocationwithPIN):
            remove(finallocationwithPIN)
        else:
            pass
        if not lyt.mapSeries is None:
            ms = lyt.mapSeries
            lyt.mapSeries.refresh()
            if ms.enabled:
                ms.currentPageNumber = ms.getPageNumberFromName(PIN)
                ms.exportToPDF(finallocationwithPIN)
HaydenWelch
MVP Regular Contributor
In your example the layout object is the "lyt" object. Instead of using the mapseries in your loop, you just export the layout because after you set the active page the layout object holds that page.
So instead of the last line being "ms.exportToJPEG" it would be "lyt.exportToJPEG"
Sorry for the formatting I'm on mobile
RhettZufelt
MVP Notable Contributor
what does print(finallocationwithPIN) return?
R_
ScoutStanley
It returns the final location of where I want the layouts exported to.
ScoutStanley
When I run script with  exportToJPEG, the error I get is..
AttributeError: 'MapSeries' object has no attribute 'exportToJPEG'
        else:
            pass
            ms = lyt.mapSeries
            if ms.enabled:
                ms.exportToJPEG(f'{finallocationwithPIN}.jpg')
EarlMedina
The MapSeries itself has no exportToJPEG method is what's going on. What you're supposed to do is set the map series current page (as you are doing) and then export from the Layout object. I believe that means your last line should be:
lyt.exportToJPEG(finallocationwithPIN)
ScoutStanley
Can you explain the what you mean by export from the layout object?
EarlMedina
Take a look at example 2 here: MapSeries—ArcGIS Pro | Documentation. It's quite similar (I think) to what you're hoping to do.
HaydenWelch
ScoutStanley
AH I see! Thank you for pointing out issue so clearly!! I was so deep in the weeds I was missing the obvious! Much appreciation!
