Loop to make layers and create maps
3073
10
03-05-2012 08:14 AM
EvaJenkins
I have a python script (arcpy) that is used to create a list of unique values of a field, then I want to loop through those values and make a feature layer for each, update map text, update symbology, and export to a PDF.  So far, the issue seems to be linking the value of the field in the feature class with the value in the unique values list.  The script appears to work aside from this (i.e. exports nice maps with no data).  Can anyone help me with that link and the where clause in the MakeFeatureLayer tool?
import arcpy.mapping
arcpy.env.overwriteOutputs = True
inFC = r"F:\DATA\PROJECTS\RUBL\layers\RUBL.gdb\National_bothtimeperiods"
inField = "survey_month"
mxd = arcpy.mapping.MapDocument(r"F:\DATA\PROJECTS\RUBL\workspaces\RUBL_National_Monthly.mxd")
df = arcpy.mapping.ListDataFrames(mxd, "Layers")[0]
outloc = r"F:\DATA\PROJECTS\RUBL\maps\Month"
sourcelayer = arcpy.mapping.ListLayers(mxd, "Survey Records", df)[0]
valueList = []
rows = arcpy.SearchCursor(inFC)
for row in rows:
  aVal = row.getValue(inField)
  if aVal not in valueList:
    valueList.append(aVal)
del row, rows
print valueList
for value in valueList:
  #make feature layer where survey_month field equals the current value in the unique list
  lyrbase = "MonthLyr"
  val = str(value)
  lyrname = lyrbase + value
  arcpy.MakeFeatureLayer_management(inFC, lyrname, "[survey_month] = value")
  arcpy.RefreshTOC()
  #update symbology based on layer in mxd
  for lyr in arcpy.mapping.ListLayers(mxd, lyrname,df):
    arcpy.mapping.UpdateLayer(df, lyrname, sourcelayer, True)
  #change the text element to read the month of the current unique value
  for elm in arcpy.mapping.ListLayoutElements(mxd, "TEXT_ELEMENT", "Month"):
    elm.text = "Month: " + value
  #export to PDF with settings
  outfile = outloc + value
  arcpy.mapping.ExportToPDF(mxd, outfile, data_frame="PAGE_LAYOUT", resolution=300, image_quality="BEST", colorspace="CMYK", image_compression="LZW", convert_markers="True", embed_fonts="True")
  #remove the current layer so that the next can be created and mapped correctly
  for df in arcpy.mapping.ListDataFrames(mxd):
    for lyr in arcpy.mapping.ListLayers(mxd, lyrname, df):
      arcpy.mapping.RemoveLayer(df, lyr)
BruceNielsen
The statement 'val = str(value)' implies that value is not a string, but on the next line 'lyrname = lyrbase + value' you're trying to append it onto the end of a string. Do you want to use 'lyrname = lyrbase + val' instead?
MathewCoyle
Honored Contributor
This is probably more what you want. I assume you aren't looking for an attribute of "value". Also, I am not sure if the square brackets are needed.
where =  "[survey_month] = " + value
arcpy.MakeFeatureLayer_management(inFC, lyrname, where)
EvaJenkins
Yes, you are right, the layername should have the string version attached
EvaJenkins
I tried this solution but I'm getting an error as follows:
  File "F:\DATA\PROJECTS\RUBL\docs\month_mapping.py", line 34, in <module>
TypeError: cannot concatenate 'str' and 'float' objects
EvaJenkins
oh, I think that is because I was using the float value not the one converted to a string, used the val variable instead with your solution but am still getting no data showing up on the final map...
MathewCoyle
Honored Contributor
If it is a string field it will need to be formatted as such. Something like this should work.
where =  "[survey_month] = '" + value + "'"
You can try building a sample query in arcmap to get your formatting down.
EvaJenkins
My problem is that it is not a string field...it is a double with values between 1 and 12 for month.
MathewCoyle
Honored Contributor
Try posting the code you are using now with the
 tags so it is formatted properly.
If it is just 1-12, you could just use an integer, but that is beside the point. Have you put an arcpy.RefreshActiveView() in after you add your layers?
EvaJenkins
Is there a special way to format a variable to be read as an integer within a where clause?  I added in the refresh function, but still get blank outputs (supposedly because nothing "equals the variable")....
valueList = []
for row in rows:
del row, rows
print valueList
  val = str(value) #this is done just so I can use it for naming
