loop through  a list of mxds (user input)
4630
01-29-2013 04:48 AM
JeromeWeis
Hello, everybody!
I have adapted a script that changes the data sources of the layers in one mxd provided by user input.
All I want is to have this script accept multiple mxds from user and loop through the script.
I know this situations has been described before, however I was not able to implement the advice found here.
I am at the very beginning of my python experience, therefore any help on this would be much, much appreciated.
I paste in the code with my trial for multiple mxd input:
import arcpy
#set new SDE connection
newSdePath = r"Database Connections\myConnection.sde"
#get mxds  as input from user
mxdAr = arcpy.GetParameterAsText(0)
mxd = arcpy.mapping.MapDocument(mxdAr)
#parse through the list of mxds, dataframes, layers; change data sources
for mxdItem in mxd.split(";"):
        for df in arcpy.mapping.ListDataFrames(mxd):
                for lyr in arcpy.mapping.ListLayers(mxd, ""):
                        if lyr.isFeatureLayer== True:
                             lyr.replaceDataSource(newSdePath, "SDE_WORKSPACE","", False)
arcpy.RefreshTOC()
arcpy.RefreshActiveView()
mxd.save()
del mxd
The error i get :
File "D:\Program Files (x86)\ArcGIS\Desktop10.1\arcpy\arcpy\arcobjects\mixins.py", line 608, in __init__
    assert (os.path.isfile(mxd) or (mxd.lower() == "current")), gp.getIDMessage(89004, "Invalid MXD filename")
AssertionError: Invalid MXD filename.
Thank you for your help!
JakeSkinner
Esri Esteemed Contributor
Hi Jerome,
You could use the glob module to do this.  Here is an example:
import arcpy, glob
for file in glob.glob(arcpy.GetParameterAsText(0) + r"\*.mxd"):
    mxd = arcpy.mapping.MapDocument(file)
    mxd.save()
del mxd
In the above example, set the data type for 'arcpy.GetParameterAsText' as 'Folder'.  The above code will then loop through the specified folder and update all MXDs.
ChrisPedrezuela
This should solve the issue,
import arcpy
mxdAr = arcpy.GetParameterAsText(0).split(";")
for mxdItem in mxdAr:
    mxd = arcpy.mapping.MapDocument(mxdItem.strip("'"))
            arcpy.RefreshTOC()
    mxd.save()
del mxd
When you add the script as a tool, in its properties, the user input is set as Map Document and Multivalue.
Hello, everybody!
import arcpy
arcpy.RefreshTOC()
mxd.save()
del mxd
The error i get :
JeromeWeis
Thank you very much!
I learned something new.
It worked perfectly! It's not my victory...but feels good!
Cheers!
Hi Jerome,
import arcpy, glob
    mxd.save()
del mxd
JeromeWeis
Hi, there!
The same as above. Thank you very much!
It was so simple, but without you, I couldn't have done it. I learned something!
Much appreciated!
Cheers!
Jerome
import arcpy
            arcpy.RefreshTOC()
    mxd.save()
del mxd
