Linear trend has to pass through the origin
2189
08-14-2012 10:44 AM
JoseLuis_Serrano
Hi - I need to interpolate a linear trend surface through a really big number of points but with the condition that the surface has to pass exactly through one of them, like the origin point.
I couldn't find any option for that in the trend tool so I though about creating a lot of points really close to the origin point to force the trend but since I already have so many points I get an out of memory error.
Does someone know if there is another way of doing this? I am using python to perform this analysis so I though about converting the points to a numpy array but so far I haven't found anything in numpy to calculate the trend.
Thanks a lot for your help!
Jose Luis Serrano
GIS Programmer/Analyst
ChristopherThompson
I think that almost by definition a trend surface is never going to pass through your data points because it uses a least-squares regression to accomplish this, so a different interpolation method might be needed if this is a requirement - for instance the spline techniques force your interpolated surface through the original data points.
JoseLuis_Serrano
You can force a linear regression to pass through the origin of coordinates. The best way I have found so far it is to convert the raster to a numpy array, move the coordinate system so my origin of coordinates is the point I want to pass through, create a least square model using numpy.linalg.lstsq where Z = aX + bY + c and c = 0, and then use the model to create the raster.
I'll let you know if it works.
ChristopherThompson
Please do, the math side of this certainly isn't my strong point so I'll be interested to see the results and what you accomplish.
