java.lang.Exception - Could not service request error obtained on using arcpy.mp.LayerFile in geoprocessing Tool on ArcGIS Server
4005
07-11-2021 01:55 PM
SarthakBhatia1
I'm using arcpy.mp.LayerFile() to read a .lyrx file to further obtain the symbology object of an active layer in the template lyrx file. This symbology is then used to generate a new lyrx for another file.
Now this script works perfectly fine when used as a geoprocessing Tool in ArcGIS Pro or as a stand-alone script working on Windows Task scheduler but it fails to work as a hosted geoprocessing tool on ArcGIS Server 10.7.
DamianoMontrasio
I've same issue with :
# Apply the symbology from the symbology layer to the input layer
arcpy.ApplySymbologyFromLayer_management (output, os.path.join(path,mylyr))
I received java.lang.Exception error only in geoprocessing service execution.
Work fine in ArcGIS Pro.
Thanks in advance...
