iteration over non-sequence
2032
04-08-2012 08:40 PM
AdelItani
Please help me to correct this error:
# List all FOLDERS in master workspace
workspaces = gp.ListWorkspaces(dataFolders, "Folder")
# Iterate through the workspaces one at a time
for workspace in workspaces:
#  Error:iteration over non-sequence
MathewCoyle
Honored Contributor
You never mentioned what version of ArcGIS/Python you are using.
You need to set a workspace first.
You set a folder path (I presume) in the wildcard parameter.
See the help for info on how to use correct syntax.
http://webhelp.esri.com/arcgisdesktop/9.3/index.cfm?TopicName=ListWorkspaces_method
AdelItani
Thanks Mathew,
I am using ArcGIS 9.2/Python 2.4 IDLE, CPython Windows XP.
import arcgisscripting
gp = arcgisscripting.create()
gp.OverWriteOutput = 'True'
gp.workspace = startFromFolder  # d:\projects\New\DaTa
workspaces = gp.ListWorkspaces(dataFolders, "Folder")  ## part_01
    When using a 9.2-version geoprocessor,
    ListWorkspaces returns an enumeration instead of a Python List.
What's the difference between enumeration and Python List ?
MathewCoyle
Honored Contributor
Enumerations from what I understand are an obsolete (in python) method of accessing data. Back when enumerations were popular I hadn't even heard of python yet, so I'm afraid I won't be much use.
BruceNielsen
Processing the enumeration from gp.workspaces looks something like this:
ws = workspaces.next() #get the first item in the enumeration
while ws: #repeat as long as ws has a value
    ws = workspaces.next() #usually the last line in the while loop
