Iterating through 7740 fileds to select and delete the fields less than certain values (rainfall data)
3343
06-15-2022 02:03 PM
HadiK
I have a point data which has 7740 fields precipitation value in each column for 60 million pixels.
I need to get rid of the columns (Daily Data) which is the date of my attribute table those are has values less than 100 mm of precipitation, find it and delete those columns (7740) . I want to do this to lighten my data for web service.
I want to do it in arcpy and I'm somehow confused how to do it.
Could you please help me with this.
import os
import arcpy
from arcpy import env
table = "Test_area_cliped"
fields = [f.name for f in arcpy.ListFields(table)]
I got all the fields now in my code but I do not know how to done it.
Tags (1)
2 Solutions
MarkBryant
Build a list of the fields where the precipitation is less than 100. There a number of tools that could do this including "Summary Statistics", but I have include a way to do this with numpy. Once you have the list of fields, pass it to the delete fields tool.
import numpy
import arcpy
def get_maximum_field_value(in_table, field_name):
    """Return the maximum value of a field in a table. Using Numpy."""
    data = arcpy.da.TableToNumPyArray(in_table, [field_name])
    return numpy.max(data[field_name])
delete_fields=[]
for field in fields:
    precipitation = get_maximum_field_value(table, field)
    if precipitation < 100:
        delete_fields.append(field)
arcpy.DeleteField_management(table, delete_fields)
Mark.
MarkBryant
The ValueError  could be raised if you have nothing but null values in a column.
You could try changing the function checking for the maximum value to change null values to zeros.
    data = arcpy.da.TableToNumPyArray(in_table, [field_name], null_value=0)
Mark.
MarkBryant
import numpy
import arcpy
delete_fields=[]
Mark.
HadiK
Thank you for your response and help!
After input this lines of code I got the following error:
delete_fields=[]
ValueError: zero-size array to reduction operation maximum which has no identity
Did I do something in wrong way?
Attached screenshot of my attribute table, it's like this for 7459 days. Of course most of the data have zero values. (Precipitation data)
MarkBryant
Mark.
HadiK
Thank you so much for your response,
Seems it worked. Good. But I'm not able to apply it or display the new data?1
When I print field it shows me 'lon'
When I print fields it shows me the whole fields name only.
Am I doing something wrong here?! Cause I did exactly as you said 
