'isOverflowing' not recognised as an Property: arcpy.mapping.ListLayoutElements
1198
04-18-2013 12:36 PM
AdrianRingenbach1
I try to export a bunch of layers with the arcpy.mapping.ListLayoutElements function. Each layer should be exported as a single .jpg-map and each with a legend. Because not all layers have the same number of classes the legends have different sizes. To approach this issue, i wanted to use the following piece of code:
#LEGENDSTUFF: print "legende generieren" legend=arcpy.mapping.ListLayoutElements(mxd,"LEGEND_ELEMENT","Legend")[0] legend.autoAdd = True while legend.isOverflowing == True:    legend.elementHeight = legend.elementHeight +0.1
Here I was obviously inspired by the 2nd legend example on the official help page: http://resources.arcgis.com/en/help/main/10.1/index.html#//00s300000041000000
But i get the followong error message:
  File "H:\Desktop\Masterarbeit\Python scripts\map_production_test 6.py", line 98, in <module>
AttributeError: 'LegendElement' object has no attribute 'isOverflowing'
Does anyone see, what I do wrong? I use ArcGIS 10.1...  (even if it seems i've got an older version)...
To better convey to the relationship i post here my whole code.  But tob e honest, i dont think that is necessary (and i has still several constructions sites..)...  Even the print messages or some comments  are sometimes in german: Sorry for  that...
print "START map production"  print "arcpy and os importieren" import arcpy import os, sys, string print "done arcpy and os and so on import"  #Workspacedefinitionen workspace = r"H:\Desktop\Masterarbeit\test\RESULTATE" arcpy.env.workspace = workspace out_dir=r"H:\\Desktop\\maps\\e95ci\\" counter = 1 name_var= "test__" + str(counter) + ".jpg" outfile = os.path.join (out_dir, name_var)  #Specifies layer file with the symbology you want to apply to the other raster layers sourceLayer1 = arcpy.mapping.Layer(r"H:\Desktop\Masterarbeit\test\RESULTATE\lyr_files_neu\E_95CI.lyr")    sourceLayer2 = arcpy.mapping.Layer(r"H:\Desktop\Masterarbeit\test\RESULTATE\lyr_files_neu\E_95CI_diff.lyr")    sourceLayer3 = arcpy.mapping.Layer(r"H:\Desktop\Masterarbeit\test\RESULTATE\lyr_files_neu\E_mean.lyr")    sourceLayer4 = arcpy.mapping.Layer(r"H:\Desktop\Masterarbeit\test\RESULTATE\lyr_files_neu\E_mean_diff.lyr")    sourceLayer5 = arcpy.mapping.Layer(r"H:\Desktop\Masterarbeit\test\RESULTATE\lyr_files_neu\Nr_depos_diff.lyr")    sourceLayer6 = arcpy.mapping.Layer(r"H:\Desktop\Masterarbeit\test\RESULTATE\lyr_files_neu\Nr_deposited.lyr")    sourceLayer7 = arcpy.mapping.Layer(r"H:\Desktop\Masterarbeit\test\RESULTATE\lyr_files_neu\Nr_pass_diff.lyr")    sourceLayer8 = arcpy.mapping.Layer(r"H:\Desktop\Masterarbeit\test\RESULTATE\lyr_files_neu\Nr_passages.lyr")    sourceLayer9 = arcpy.mapping.Layer(r"H:\Desktop\Masterarbeit\test\RESULTATE\lyr_files_neu\Nr_tree_impacts.lyr")    sourceLayer10 = arcpy.mapping.Layer(r"H:\Desktop\Masterarbeit\test\RESULTATE\lyr_files_neu\Ph_95CI.lyr")    sourceLayer11 = arcpy.mapping.Layer(r"H:\Desktop\Masterarbeit\test\RESULTATE\lyr_files_neu\Ph_95CI_diff.lyr")    sourceLayer12 = arcpy.mapping.Layer(r"H:\Desktop\Masterarbeit\test\RESULTATE\lyr_files_neu\Ph_mean.lyr")    sourceLayer13 = arcpy.mapping.Layer(r"H:\Desktop\Masterarbeit\test\RESULTATE\lyr_files_neu\Ph_mean_diff.lyr")    sourceLayer14 = arcpy.mapping.Layer(r"H:\Desktop\Masterarbeit\test\RESULTATE\lyr_files_neu\Reach Probability [%].lyr")    sourceLayer15 = arcpy.mapping.Layer(r"H:\Desktop\Masterarbeit\test\RESULTATE\lyr_files_neu\Reach_prob_diff.lyr")    sourceLayer16 = arcpy.mapping.Layer(r"H:\Desktop\Masterarbeit\test\RESULTATE\lyr_files_neu\Rvol.lyr")    sourceLayer17 = arcpy.mapping.Layer(r"H:\Desktop\Masterarbeit\test\RESULTATE\lyr_files_neu\Rvol_diff.lyr")    sourceLayer18 = arcpy.mapping.Layer(r"H:\Desktop\Masterarbeit\test\RESULTATE\lyr_files_neu\Tree_impact_heights .lyr")    sourceLayer19 = arcpy.mapping.Layer(r"H:\Desktop\Masterarbeit\test\RESULTATE\lyr_files_neu\Vmax.lyr") sourceLayer20 = arcpy.mapping.Layer(r"H:\Desktop\Masterarbeit\test\RESULTATE\lyr_files_neu\Vmax_diff.lyr")   #Specifies Functions def shortname(name):    name = name.rpartition("\\SH_")[2]    print name    name = name.replace(".","_")    name = name.replace("\\","_")    name = name.replace("_mdb_","_")    print "this is the used name: "+ name    return name  print "specify mxd" #Specifies mxd   mxd = arcpy.mapping.MapDocument(r"H:\\Desktop\\Masterarbeit\\test\\test1.mxd") print "done mxd spezifizieren"  print "specify dataframe" #Specifies dataframe of interest df = arcpy.mapping.ListDataFrames(mxd, "Layers")[0] print "done specify df "  #Turns all layers off print "turn visibility of all layers off" for lyr in arcpy.mapping.ListLayers(mxd,"",df):    lyr.visible = False    arcpy.RefreshTOC()    arcpy.RefreshActiveView()     print "visibility = False"  #Turns backgroundlayers on print "turn backgroundlayer on: Visibility = true"  for lyr in arcpy.mapping.ListLayers(mxd, "hill*", df):    print lyr    lyr.visible = True    arcpy.RefreshTOC()    arcpy.RefreshActiveView() for lyr in arcpy.mapping.ListLayers(mxd, "up*", df):    print lyr    lyr.visible = True    arcpy.RefreshTOC()    arcpy.RefreshActiveView() for lyr in arcpy.mapping.ListLayers(mxd, "swiss*", df):    print lyr    lyr.visible = True    arcpy.RefreshTOC()    arcpy.RefreshActiveView() print "background = visible"  #lEGENDSTUFF: print "legende generieren" legend=arcpy.mapping.ListLayoutElements(mxd,"LEGEND_ELEMENT","Legend")[0] legend.autoAdd = True while legend.isOverflowing == True:    legend.elementHeight = legend.elementHeight +0.1  print "start withE_95CI" #Loops through the layers given in the quotas (eg. beginning with E_95CI) and creates a list of Layers: for lyr in arcpy.mapping.ListLayers(mxd, "E_95CI", df):     print lyr     if lyr.isRasterLayer:         arcpy.ApplySymbologyFromLayer_management(lyr, sourceLayer1)     #For Each: Turn it on:     lyr.visible = True     print " visible: on"        name =lyr.dataSource     name=shortname(name)     #name = name.rpartition("\\SH_")[2]     #print name     #name = name.replace(".","_")     #name = name.replace("\\","_")     #name = name.replace("_mdb_","_")     print "this is the used name: "+ name            arcpy.RefreshTOC()     print " TOC refreshed"     arcpy.RefreshActiveView()     print " Active View refreshed"       print "exporting .JPG"     mxd.activeView = "PAGE_LAYOUT"     arcpy.mapping.ExportToJPEG(mxd, r"H:\\Desktop\\maps\\e95ci\\SH_" + name+ ".jpg")     lyr.visible  = False       #legend=arcpy.mapping.ListLayoutElements(mxd,"LEGEND_ELEMENT","")[0]      #legend=arcpy.mapping.ListLayoutElements(mxd, "LEGEND_ELEMENT")[0]     #legend.autoAdd = True #newlz added lazers will be automaticallz added to the legend     #legend.elementHeight=4     #legend.elementWidth=4       for lyr in arcpy.mapping.ListLayers(mxd, "N*", df):     print lyr     if lyr.isRasterLayer:         arcpy.ApplySymbologyFromLayer_management(lyr, sourceLayer6)     #For Each: Turn it on:     lyr.visible = True     print " visible: on"     print " this is the Source"     name =lyr.dataSource     name=shortname(name)     print "this is the used name: "+ name     arcpy.RefreshTOC()     print " TOC refreshed"     arcpy.RefreshActiveView()     print " Active View refreshed"     print "exporting .JPG"     mxd.activeView = "PAGE_LAYOUT"     arcpy.mapping.ExportToJPEG(mxd, r"H:\\Desktop\\maps\\nr_deposited\\SH_" + name + ".jpg")     lyr.visible  = False             #     #print legend     #legend=arcpy.mapping.ListLayoutElements(mxd, "LEGEND_ELEMENT")[0]     #legend.autoAdd = True #newlz added lazers will be automaticallz added to the legend     #legend.elementHeight=4     #legend.elementWidth=4       print "done_"    #print "start reach_probability" ##Loops through the layers given in the quotas (eg. reach_probability) and creates a list of Layers: #for lyr in arcpy.mapping.ListLayers(mxd, "reach_probability", df):     #For Each: Turn it on: #   lyr.visible= True #   arcpy.RefreshTOC() #   arcpy.RefreshActiveView() #   arcpy.mapping.ExportToJPEG(mxd, r"H:\\Desktop\\map_export\\" + outfile, df)  #print"done_2"   #Saves mxd   print "__________________________________________" print "_xxx____xx___xx___x__xxxxx________________" print "_x__x__x__x__x_x__x__x____________________" print "_x__x__x__x__x__x_x__xxx__________________" print "_xxx____xx___x___xx__xxxxx________________" print "__________________________________________"  #Deletes the reference to the mxd from memory (not the actual mxd file) del mxd
AdrianRingenbach1
Sorry for bothering you, but it finally came out, that my university still has the version 10.0. Recently, hey were just speaking about the update, and not as I thought, realising it...   😞
But thanks anyway!
curtvprice
Is the legend property checkbox set to FixedFrame in the ArcMap interface? The help implies that that has to be the case for this property to be used.
AdrianRingenbach1
But thanks anyway!
