Is there a possibility to split a polygon in the middle?
4090
6
09-17-2015 10:09 PM
JohannesBierer
Maybe calculate centroid and then create a split line throught that point?
Or maybe a comparable function like split polygon in the polytool for arcview 3?
DanPatterson_Retired
In an edit session you can do that easily.
I presume that you have more than one to split, and there are no existing tools in the Editing Toolbox that will do this (for reference
http://desktop.arcgis.com/en/desktop/latest/tools/editing-toolbox/an-overview-of-the-editing-toolbox... )
Have you examined the ET Geowizards etc tools at
http://www.ian-ko.com/ There are often tools there that will be useful.
If you need to split by a particular parameter, such as equal area, there are advanced tools in arcmap and on the web.  For instance
http://desktop.arcgis.com/en/desktop/latest/manage-data/editing-parcels/dividingparcelsbyarea.htm
So given your requirements, your options are pretty well up in the air.
JayantaPoddar
Hello,
You could try Parcel Division tool in Parcel Fabric(Standard/Advanced license required)
Dividing parcels by area—Help | ArcGIS for Desktop
Think Location
Jayanta...check my last link, same reference
JohannesBierer
Parcel division would be the right answer, unfortunately I have version 10.1 🙂
check for it, it requires a standard or advanced licence not basic.  I thought it had been around for a while.  The help link I sent is for 10.3 since there have been issues with the pre 10.3 help files
try this if you have the appropriate licence
http://resources.arcgis.com/search/?do=search&start=0&filter=0&lg=en&product=&version=10.2&collectio...
JohannesBierer
You need 10.2 ... but thanks
