Is "LENGTH" no longer an option for CalculateGeometryAttributes()?
1066
01-29-2026 10:55 AM
GB_MattPanunto_GISS
Using ArcGIS Pro v3.5.5, and trying to calculate planar feet for a line feature class:
arcpy.management.CalculateGeometryAttributes(in_features=line_fc, geometry_property=[["Length", "LENGTH"]], length_unit="FEET_INT")
However, I'm getting an error that says "LENGTH" is no longer an accepted input value, and that I can only use "LENGTH_GEODESIC" or "LENGTH_3D". It is still listed in ESRI's documentation as an option though, and is also an option when calculating geometry via ArcGIS Pro GUI.
Here is the error:
arcgisscripting.ExecuteError: Failed to execute. Parameters are not valid.
ERROR 000800: The value is not a member of LENGTH_GEODESIC | LENGTH_3D | LINE_BEARING | PART_COUNT | POINT_COUNT | CURVE_COUNT | LINE_START_X | LINE_START_Y | LINE_START_Z | LINE_END_X | LINE_END_Y | LINE_END_Z | CENTROID_X | CENTROID_Y | CENTROID_Z | INSIDE_X | INSIDE_Y | INSIDE_Z | EXTENT_MIN_X | EXTENT_MIN_Y | EXTENT_MIN_Z | EXTENT_MAX_X | EXTENT_MAX_Y | EXTENT_MAX_Z.
Failed to execute (CalculateGeometryAttributes).
Wondering if this is a bug, or if it's removal from arcpy() is intentional? For what it's worth, that line of code worked for me in ArcGIS Pro v3.3.2, prior to upgrading to v3.5.5. For now, I've coded up a workaround using !shape.length@feet!
VenkataKondepati
Honored Contributor
It looks to me that it is intentional.
You can try below code as a workaround.
arcpy.management.CalculateField(line_fc, "Length_Feet", "!shape.length@feet!", "PYTHON3")
Calculate Field (Data Management)—ArcGIS Pro | Documentation
Regards,
Venkat
Follow me on: LinkedIn
If this response helps or is the solution to your post, please consider marking it as a solution
DanPatterson
MVP Esteemed Contributor
is "Length" and existing field name in the geodatabase? (checking for a reserved word trigger),
if it isn't try using a different name.
There are no publicly facing bugs bugs on the Support web site for this version of Pro
... sort of retired...
GB_MattPanunto_GISS
@DanPatterson , I'm getting the same error for other feature classes in separate GDBs where "Length" is not being used as a field name.
@VenkataKondepati, after reading the CalculateField documentation more thoroughly, I noticed this syntax can be used: !shape!.getLength('PLANAR', 'FeetInt'), which is helpful because it allows you to control both the measurement method (Geodesic vs Planar) and the output unit.
VenkataKondepati
Honored Contributor
Yes. This should work as well.
Regards,
Venkat
