Invalid Syntax Error Assistance
1740
05-09-2025 08:34 AM
RemyCrettol
Hey all, I am trying to use ArcGIS and Python code to prioritize and map river corridor protections for flood resilience. I am struggling with this line of code that is giving me a SyntaxError: invalid syntax. I think it is trying to read 'Mulitple' as part of the code and not as a word/value.  See line 4 error below as well as full code under that. Really been struggling to resolve this so any assistance would be much appreciated.
File "<string>", line 4
if (Upstream_MassFailures == 'multiple' and upstream_constrained = 1):
 __________________________________________________________________________________________________
def calculate_sediment_loaded(confinement_type, ChannelEvolutionStage, GeomorphicStreamCondition, GeoAssessSensitivity, Upstream_MassFailures, constrained, upstream_constrained😞
    #  Check if the reach is downstream of a constrained reach with mass failures and conditions are met
    if (Upstream_MassFailures == 'Multiple' and upstream_constrained = 1):
        # Count how many primary criteria are met
        criteria_met = sum([
            confinement_type in ('BD', 'VB'),
            ChannelEvolutionStage in ('III', 'IV'),
            GeoAssessSensitivity in ('Very High', 'Extreme'),
            GeomorphicStreamCondition in ('Fair', 'Poor')
        # If at least 3 out of 4 conditions are met, return 1
        if criteria_met >= 3:
            return 1
elif (upstream_percent_straightened > 40 and straightening_percent is not None and straightening_percent <= 40):
            return 1
elif (Constrained is not None and constrained = 0 and upstream_constrained = 1):
            return 1
 return 0  # Default case if conditions aren't met
DanPatterson
MVP Esteemed Contributor
if (Upstream_MassFailures == 'multiple') and (upstream_constrained == 1):
you forgot the last = hence it errored.   I put in a couple of extra enclosing ( )'s for good measure
... sort of retired...
DanPatterson
RemyCrettol
You are my hero, thank you so much!
KenBuja
Don't forget to make the same change in the last elif
