Invalid literal for int() with base 10.
10752
07-23-2013 02:51 PM
ScottBarron
Hi, I keep getting this error message:
Traceback (most recent call last):   File "C:\Users\sbarron\Desktop\AIDA_Tool\AutoInfastructureMask.py", line 123, in <module>     Max= int(max(Quakesim_List)) ValueError: invalid literal for int() with base 10: '999.332202045'
And I have no idea why. This code has worked on bigger numbers than this one, so I'm completely stumped. Any help would be appreciated.
-Scott
RhettZufelt
MVP Notable Contributor
It appears that maybe your list contains strings  '999.332202045'
Try this, might work for you, will make sure if string, converts to float, then int:
 Max= int(float(max(Quakesim_List)))
ScottBarron
Oh and for reference, the list in the code is just a list full of floating point numbers.
RhettZufelt
JasonScheirer
Esri Alum
Your variables in Quakesim_List are strings, hence the failure.
int(max(float(sim) for sim in Quakesim_List))
Do that.
ScottBarron
Apparently it was a case of bad data. I tried with the float inserted into the code and it worked but it gave me a messed up output. I regenerated the data and it worked just fine. Thanks for your help!
