Intersecting Lists Problem
5937
14
03-19-2019 03:08 PM
AlanDodson
First post here, please be gentle...
I use ArcMap 10.3.1 and I'm having trouble with part of a Python script which will always be run from the Current mxd and active data frame.
I have to pass a list of layers to a function. I have given the script a list of all potential layers for this function (List 1).  Some of those potential layers will actually be in my active data frame (always at least 1), along with other layers that are not compatible with the next function (List2).  I want to only work with the potential layers that are actually present in my active data frame (List3)
I've tried the following:
import arcpy
mxd = arcpy.mapping.MapDocument("CURRENT")
df = mxd.ActiveDataFrame
List 1 = ["September", "October", "November", "December"]
List 2 = arcpy.mapping.ListLayers(df)  # layers are named September and December
List 3 = list(set.(List1).intersection(List2))
The result is an empty list when it should be September, December.
I think the syntax roughly works, but the problem is that List2 returns something similar to <layer u'September'> so the two layers with identical names are not recognized as such.
(For context, I'll then be using List3 to print unique messages depending on the layer name returned... In case this helps)
Can anyone help me out?
JoshuaBixby
MVP Esteemed Contributor
This works for me:
>>> df = mxd.activeDataFrame
>>> List1 = ["September", "October", "November", "December"]
>>> List2 = [lyr.name for lyr in arcpy.mapping.ListLayers(mxd, data_frame=df)]
>>> List3 = list(set(List1).intersection(List2))
>>> List3
[u'September', u'December']
PavanYadav
is returning a list of Layer objects. Something like this:
[<map layer u'September '>, <map layer u'December'>]
How about the following:
List2a = []
for l in List2:
    List2a.append(str(l.name))
Pavan Yadav
Product Engineer at Esri
AI for Imagery
Connect with me on LinkedIn!
Contact Esri Support Services
JoeBorgione
I found this with a google search:  Python | Intersection of two lists - GeeksforGeeks
and it suggests in method 2 something close to what you are trying:
def intersection(lst1, lst2):
    return list(set(lst1) & set(lst2))
lst1 = [15, 9, 10, 56, 23, 78, 5, 4, 9]
lst2 = [9, 4, 5, 36, 47, 26, 10, 45, 87]
print(intersection(lst1, lst2))
That should just about do it....
RandyBurton
As Pavan suggests, you need to use the layer's name property in your comparison.  Try:
import arcpy
List2 = arcpy.mapping.ListLayers(df)  # layers are named September and December
List3 = []
for lyr in List2:
    if lyr.name in List1:
        List3.append(lyr.name)
EDIT:  As Joshua Bixby‌ shows in his code example,  line 6 in my code should read as below. See: ListLayers.
# ListLayers (map_document_or_layer, {wildcard}, {data_frame})
List2 = arcpy.mapping.ListLayers(mxd, data_frame=df)‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
AlanDodson
Ah, this looks promising. I didn't get to the layer name before but this looks like it could solve that. I will try it out first thing in the morning and report back.
Do you know if this method preserves the list order?
RandyBurton
List3 should be in the List2 (or ListLayers) order.  It is likely that it would match the Table of Contents order.
AlanDodson
Unfortunately I'm getting an error on the line 'if lyr.name in List2:'
File "<string>" - AttributeError: 'str' object has no attribute 'name'
When I print List2 the entries are still "<layer u'September'>" or something like that so it's not matching List1 "September".  My List3 result is a list of lots of duplicates of items in List2 with the "<layer u'September'>" formatting.
PavanYadav
Did you try str(), like this:
Pavan Yadav
AI for Imagery
JoshuaBixby
This works for me:
>>> List3
AlanDodson
This works for me, thanks so much.  If anyone else reading this requires a string it requires the following change:  On line 5 change [lyr.name for ....  to [str(lyr.name) for ....
