Interesting requirement
2857
10-01-2013 10:50 AM
JamesCrandall
MVP Alum
I have an interesting requirement and looking for comments...
In order to reduce duplication of modules/def's in our codebase, I need a way to determine WHERE something is being executed from.  That is, our requirement is users will have the ability to execute a process from an ArcToolbox OR from a command line (both with args/params).
Is there a way to detect/test if it is being executed from Command line or from an ArcToolbox?  The reason is that I will need to set variables in the script with the command line args or toolbox (GetParameter).
j
JasonScheirer
Esri Alum
JamesCrandall
MVP Alum
I think I can use sys.stdout to do this...
This code, executed from PythonWin prints "pwin.framework.interact.InteractiveView at..."
value = sys.stdout
print value
This code, executed from an ArcToolbox script with the .py as source prints "geoprocessing sys.stdout object object at..."
value = sys.stdout
arcpy.AddMessage(str(value))
Any other ideas are appreciated!
JasonScheirer
Esri Alum
JamesCrandall
MVP Alum
sys.executable.
That'll work too!
Thanks Jason.
JamesCrandall
MVP Alum
Here's what I've come up with:
origapp = sys.executable
if "ArcMap" in origapp:
    arcpy.AddMessage("...The python script is being executed from ArcGIS/Toolbox")
elif "Pythonwin.exe" in origapp:
    print "...The python script is being executed from PythonWin"
