intellisense in pyscripter
1008
09-23-2011 10:22 AM
VuDang1
Pyscripter intellisense is working but not as well as the arcmap python windows.
for example
arcpy. will offer env
but
arcpy.env. will not offer workspace
Has anyone figure out how to get pyscripter intellisense to work the same as arcmap python window?
Vu
JasonScheirer
Esri Alum
Not all intellisense will work. In this case, the list of environments is generated at runtime so you won't get them as a dropdown. Nearly everything else should work though. You may want to use an interactive prompt like Idle or the Python window in ArcMap for these instances.
