Installed module but cant see it?
4919
6
07-02-2019 06:56 PM
deleted-user-yC5VkbyXzrQR
Hello,
I'm a bit new to python libraries or modules.
I want to use the pypiwin32 module in my python script.
I typed cmd into cortana search and used the python cmd. I typed pip install pypiwin32. The screen shot below shows that it's already installed.
Now when I try to import pypiwin32 in ArcPro, Juptyer, IDLE it says it doesn't exists.
I did the same with xlsxwriter module and same results. What am I doing wrong here??
DanPatterson_Retired
GitHub - mhammond/pywin32: Python for Windows (pywin32) Extensions
Tips on ActivePython, PyWin32 and virtualenv | ActiveState
How about
import win32api
dir(win32api)
['AbortSystemShutdown', 'Apply', 'Beep', 'BeginUpdateResource', 'ChangeDisplaySettings',
'EnumResourceTypes', 'ExitWindows', .... snip ....
you have permissions to install in the base environment? or did you also create a clone?
An  using
>>> conda list
…. snip ….
pywin32                   223              py36hfa6e2cd_1
pywin32's description Python extensions for Microsoft Windows Provides access to much of the Win32 API, the ability to create and use COM objects, and the Pythonwin environment.
And Mark Hammond is a maintainer.
pypiwin32 also has Mark Hammon as a maintainer, but there is no description
The difference between the two packages is listed here
Re: [python-win32] pywin32 und pypiwin32: what is the difference? « python-win32 « ActiveState List ...
so I suspect the pywin32 that is distributed by esri is fine, since they don't use wheels for distribution but conda
I had IT run python cmd as admin. I don't have admin rights to my computer.
Also when i try to import pywin32 into my script it says that there's no module installed.
When I do the conda list. It says pypiwin32 is there  ?  Idunno if that helps anything.
don't use pip if a conda variant is available, which it is, so you, or your admin, needs to do a
conda install pywin32
Dan, So i just did the conda install pywin32 and when I go to arcpro and try to import pywin32 it doesnt do anything.
How about
import win32api
dir(win32api)
NICE! I got it working thanks Dan!
