Inconsistent CalculateField with python vs VB
8806
20
09-16-2014 07:52 AM
alicexu
result of arcpy.CalculateField_management with python is inconsistent but with VB, it is ok
curtvprice
That's interesting. I think you may have to use Python with Engine - may want to contact support about that to see if there is a way.
I thought your areas calculated with and without the curves were pretty close.  Are you sure the approximation of the area using PYTHON_9.3 isn't good enough?
(25637 - 25641) / 25641 = .00015   (less than 0.02% difference)
