import arcpy Fail!
1513
7
01-31-2014 07:23 AM
BradJones
I'm a python beginner.  When I try to import arcpy in pythonwin I get this:
>>> import arcpy
  File "<interactive input>", line 1, in <module>
ImportError: No module named arcpy
I run a 64bit machine with and use ArcGIS 10.0 and Python 2.7.
Thanks in advance.
MichaelVolz
Esteemed Contributor
You might be running the 64-bit python.  You need to ensure you are calling the 32-bit python.
BradJones
I am running 64bit.  I'm in the process of changing to 32 and try that.
JoshuaChisholm
Hello Brad,
I think Michael might be right on. It's really easy to end up with multiple installs of python. I've had that issue before. One thing I'd recommend trying is importing arcpy in the IDLE interface that was installed with ArcMap (Start > All Programs > ArcGIS > Python 2.7 > IDLE (Python GUI)).
Good luck!
BradJones
I installed the 32bit version and am still getting:
PythonWin 2.7 (r27:82525, Jul  4 2010, 09:01:59) [MSC v.1500 32 bit (Intel)] on win32.
Portions Copyright 1994-2008 Mark Hammond - see 'Help/About PythonWin' for further copyright information.
>>> import arcpy
MichaelVolz
Has python been installed to c$\Python27\ArcGIS10.0 for the 32-bit version
and
to c$\Python27\ArcGISx6410.0 for the 64-bit version
You should find python.exe and pythonw.exe in these subdirectories.
BradJones
it was multiple versions.  I installed 2.7 (with PythonWin) when I had 2.6 already.
All is good.
LucasDanzinger
Esri Frequent Contributor
Do you have Python 2.7 and ArcGIS 10.0? I believe ArcGIS 10.0 shipped with Python 2.6. I'd take a look at the bottom of this help page, as it shows you the .pth file you need to direct Python to the arcpy installation location - http://help.arcgis.com/en%20/arcgisdesktop/10.0/help/index.html#//002z00000008000000
Edit-
Nevermind, glad you figured it out.
