Im Trying to use a loop to create seperate buffers for each row from attribute values
4611
8
09-08-2012 03:30 PM
OLANIYANOLAKUNLE
Im Trying to use a loop to create seperate buffers for each of the row from attribute values of a field in a  feature using searchcursor, but its not working the code i used is below;
mxd = arcpy.mapping.MapDocument("Current") df = arcpy.mapping.ListDataFrames(mxd)[0] fc = "Parcels" field = "Plot_No" cursor = arcpy.SearchCursor(fc) for row in cursor:     val = row.getValue(field) for val in fc:     outFC = str(val) + "_Buffer" + ".shp"     arcpy.Buffer_analysis(str(val),outFC,"15 meters","FULL","ROUND","NONE")
The error message
Runtime error  Traceback (most recent call last):   File "<string>", line 3, in <module>   File "C:\Program Files (x86)\ArcGIS\Desktop10.1\arcpy\arcpy\analysis.py", line 687, in Buffer     raise e ExecuteError: Failed to execute. Parameters are not valid. ERROR 000732: Input Features: Dataset K does not exist or is not supported Failed to execute (Buffer).
Please what im i doing wrong? Thanks
OLANIYANOLAKUNLE
Thanks i found a solution for my issues
See code Below;
mxd = arcpy.mapping.MapDocument("Current")         df = arcpy.mapping.ListDataFrames(mxd)[0]         fc = 'Database Connections/TDPMode.sde/KWAGISMAIN.DBO.Parcels'         field = "OBJECTID"         field1 = "LGA"         field2 = "District"         field3 = "Block_No"         field4 = "Plot_No"         rows = arcpy.SearchCursor(fc)         row = rows.next()         while row:             val = row.getValue(field)             val1 = row.getValue(field1)             val2 = row.getValue(field2)             val3 = row.getValue(field3)             val4 = row.getValue(field4)             whereClause = '"OBJECTID"' + " = '" + str(val) + "'"             outName = "Block_" + str(val3) + "_Plot_" + str(val4) + "_" + str(val2) + "_Area_of_" + str(val1) + "_LGA" + ".pdf"             path = "C:/Users/Administrator/Documents/ArcGIS/Default.gdb/"             arcpy.SelectLayerByAttribute_management("Parcels", "NEW_SELECTION", whereClause)             arcpy.Buffer_analysis ("Parcels", "DataDrivenPage_Buffer", "14 meters", "FULL", "ROUND", "NONE")             layer_list = "Lines","Parcels","Access_Road_Graphics","Points","Lines_Split"             for layer in layer_list:                 arcpy.SelectLayerByLocation_management(layer, "COMPLETELY_WITHIN", "DataDrivenPage_Buffer", "", "NEW_SELECTION")             exportLayer = "Points", "Lines", "Parcels","Lines_Split","Access_Road_Graphics"             for layer in exportLayer:                 outFC = path + layer + "_New"                  arcpy.Clip_analysis(layer,"DataDrivenPage_Buffer",outFC)                 arcpy.SelectLayerByAttribute_management(layer, "CLEAR_SELECTION")             mxd = arcpy.mapping.MapDocument("current")             lyr = arcpy.mapping.ListLayers(mxd, "Lines_New")[0]             for lblClass in lyr.labelClasses:                 lblClass.SQLQuery = '"ParcelID"' + "=" + str(val)                  arcpy.RefreshActiveView()             arcpy.SelectLayerByAttribute_management("DataDrivenPage_Buffer", "NEW_SELECTION", "OBJECTID = 1")             df.zoomToSelectedFeatures()             mxd = arcpy.mapping.MapDocument("Current")             for df in arcpy.mapping.ListDataFrames(mxd):                 df.rotation = 0             if df.scale <= 400:                  df.scale = 500             if df.scale > 400 and df.scale < 1000:                 df.scale = 1000                 else:                  df.scale = 2000             arcpy.mapping.ExportToPDF(mxd,r"C:\STATE\\Batch\\" + "TDP_For_" + outName)             row = rows.next()
I think i'm improving.....:D
FabianBlau
I guess you missunderstood the for-loop.
The second loop is outside the first.
You overwrite the val-variable in the loop.
fc holds only the name of the featureclass. Its a string/text.
for val in fc gives you the characters of the fc-name.
Try this (I did not test it):
fc = "Parcels"
field = "Plot_No"
for row in cursor:
    feat = row.getValue(shapefieldname) # this gives you the geometry
    outFC = str(val) + "_Buffer" + ".shp" # there should be no Null-values in "Plot_No", the values have to be unique
    arcpy.Buffer_analysis(feat , outFC, "15 meters", "FULL", "ROUND", "NONE")
markdenil
It may be simpler to run Buffer using your buffer_field
then using a search cursor to compile a list of buffer field values
loop through the list to select and export the buffers with each value
(make Layer then copy features)
That may be simpler than passing each feature individually to Buffer....
OLANIYANOLAKUNLE
Thanks for your response, but after trying the code it returns only 1 feature? and i want it to return a 15meters buffer for all the records
>>> fc = "Parcels"
>>> field = "Plot_No"
>>> shapefieldname = "Shape"
>>> for row in cursor:
...     feat = row.getValue(shapefieldname)
...     val = row.getValue(field)
...     outFC = str(val) + "_Buffer" + ".shp"
<Result 'C:\\Users\\Administrator\\Documents\\ArcGIS\\8_Buffer.shp'>
What is wrong?
FabianBlau
move the buffer-function into the loop.
The result will be a shapefile for every single row.
If your Plot_No-Field contains non-unique values you should mention marks answer.
OLANIYANOLAKUNLE
Thanks that did it!
OLANIYANOLAKUNLE
@ fabl and mdenil, thanks for your response...
I want to use the code you suggested to create a list of geoprocessing operations on each of the rows in a feature. I would start with the first row and generate a final pdf output, then move to the next row till the searchcursor is through with all the rows; im thinking along the line of the code you suggested but im not sure if it would take each of the rows one at a time, below is an example of what i want
fc = "Parcels"
field = "Plot_No"
for row in cursor:
    dfAsFeature = arcpy.Polygon(arcpy.Array([df.extent.lowerLeft, df.extent.lowerRight, df.extent.upperRight,     df.extent.upperLeft]),df.spatialReference)
    arcpy.Clip_analysis(lyr,dfAsFeature,outFC)
    arcpy.mapping.ExportToPDF(mxd,r"C:\KWARA_STATE\\" + outName + "\\" + outName1 + "\\" + "TDP_For_" + outName2)
fc = "Parcels"
field = "Plot_No"
for row in cursor:
Im not particularly sure if i have to repeat each of the geoprocessing operations for each row, the problem is how do i determine the no of rows? the no of rows would not be fix it can change. Your suggestions would be highly appreciated.
OLANIYANOLAKUNLE
Morning, @ fabl and mdenil im still waiting for any possibility from my last request. Thank you
OLANIYANOLAKUNLE
See code Below;
