if field.name in fieldList
2662
09-23-2014 12:42 AM
BenLeslie1
Hi
I'm trying to do a script that will search a bunch of features and tell me if they contain a certain field name or not:
fcs = arcpy.ListFeatureClasses()
for fc in fcs:
     fieldList = arcpy.ListFields(fc)
     if "CAT" in fieldList:
          print fc + " Yes"
     else:
          print fc + " Nope"
I think I've figured out that I somehow need to tell it is look for "CAT" as a field name in fieldList but I'm not sure how to write it.
I've tried a few things such as:
     if "CAT" in fieldList.field.name
but I haven't hit upon the correct syntax.
Can you help?
(just thought I'd add that everything comes out as "Nope", which isn't correct, using the above code)
AnthonyGiles
Honored Contributor
Ben,
The best way would be to to create a boolean variable that you set to true if the field name exists, something like:
for fc in fcs:
  fieldExists = false
     for field in fieldList:
        if field.name == "CAT":
          fieldExists = true
  if(fieldExists):
    print fc + " Yes"
  else:
    print fc + " No"
AnthonyGiles
Honored Contributor
Ben,
You need to iterate through each of your fields checking them individually, not tested but something like:
for fc in fcs:
          Do Something.....
        else:
          Do Something....
BenLeslie1
Thanks Anthony but it doesn't quite give me the results I'm looking for..... your answer tells me whether every fieldname in the list is "CAT" or not so the output is:
feature1.shp Nope
feature1.shp Nope
feature1.shp Yes
feature1.shp Nope
feature2.shp Nope
feature2.shp Nope
feature2.shp Nope
feature2.shp Nope
........etc
What I really want is a single yes or no for each feature.
For each feature could I somehow concatenate all the fieldnames into a single string and test that?
AnthonyGiles
Honored Contributor
Ben,
for fc in fcs:
  fieldExists = false
          fieldExists = true
  if(fieldExists):
    print fc + " Yes"
  else:
    print fc + " No"
