If else statement
14314
63
08-28-2013 04:39 AM
JamesSmith7
I am modifying a script suggested in a prior thread.  http://forums.arcgis.com/threads/90242-Polygon-Centroid?highlight=jsmith0705
I want to be able to select a line, determine if the ARCLENGTH field has a value greater than zero, return that value if greater than zero, if not return the value from the Shape_Length field.
The script runs with no errors or results.
import arcpy  mxd = arcpy.mapping.MapDocument ("CURRENT") df = arcpy.mapping.ListDataFrames (mxd)[0]  lyr = arcpy.mapping.ListLayers(mxd, "Lot_Lines", df)[0]  for lyr in arcpy.mapping.ListLayers(mxd):  tlyr = lyr  dsc = arcpy.Describe(tlyr)  sel_set = dsc.FIDSet  if dsc.shapeType == "Line":   if len(sel_set) > 0: #If ARCLENGTH value > 0           arcpy.AddMessage(str(ARCLENGTH)) #Return ARCLENGTH value   else:    arcpy.AddMessage(str(Shape_Length)) #Return Shape_Length value
JamesSmith7
Richard,
Can you point me in the direction to read up on the OBJECTID IN operator?  It looks like I may need to select more than one Polyline at a time.
RichardFairhurst
Richard,
ESRI has virtually nothing about it.  It's a simple expression.  All you need is the field name followed by the word IN and then a comma separated list of correctly typed values within a pair of parentheses.  I already gave several examples.  Any single value in the list that matches the value of the field for any given record will be included in the selection.  You would need to output the python list as a comma separated list in one string.  I believe this will work to convert a python list of numbers to a comma separated list:
myList = [12,34,56,78,90]
myString = ",".join(myList)
and then you could make the where clause using the appropriate field delimiters for your database:
'"OBJECTID" IN (' + myString + ')'
In the case of your latest code, I think that the dsc.fidSet is already a string so I think you can use replace to substitute semicolons with commas:
mxd = arcpy.mapping.MapDocument("CURRENT")
    dsc = arcpy.Describe(lyr)
    sel_set = dsc.fidSet.replace(";",",")
    if dsc.shapeType == "Polyline":
        rows = arcpy.da.SearchCursor(lyr, ["OID@", "ARCLENGTH", "SHAPE@LENGTH"], "OBJECTID IN (" + sel_set + ")")
        for row in rows:
            arcLength = row.[1]
            shapeLength = row.[2]
            if arcLength > ' ':
                print arcLength
            else:
                print shapeLength
    del row, rows
I changed it to a da cursor, since performance is about 10 times faster or more than the old cursor style.  You would still need to replace the print methods with AddMessages and I indented the arcLength test so that each line feature will print.  The test also will handle single digit arcLength values now that I know it is a string field (although you probably don't have any single digit values in the field).
JamesSmith7
I was hoping ESRI or the forums contained attitional information.  I also have a book that covers Python and the OBJECTID IN operator is not mentioned.
JakeSkinner
Esri Esteemed Contributor
James,
Here is tech article that discusses selecting multiple values:
http://support.esri.com/en/knowledgebase/techarticles/detail/32024
Try the below.  It should work whether you select one line or multiple lines:
        if len(sel_set) > 1:
            sel_set = sel_set.replace(";", ",")
            arcLengthList = []
            shapeLengthList = []
            rows = arcpy.SearchCursor(lyr, "OBJECTID IN (" + sel_set + ")")
            for row in rows:
                arcLengthList.append(row.ARCLENGTH)
                shapeLengthList.append(row.shape.length)
            i = 0
            while i < len(arcLengthList):
                if len(arcLengthList) > 1:
                    print arcLengthList
                else:
                    print shapeLengthList
                i += 1
        else:
            rows = arcpy.SearchCursor(lyr, "OBJECTID = " + sel_set)
            for row in rows:
                arcLength = row.ARCLENGTH
                shapeLength = row.shape.length
            if len(arcLength) > 1:
                print arcLength
            else:
                print shapeLength
    del row, rows
RichardFairhurst
James,
            arcLengthList = []
            for row in rows:
            i = 0
                    print arcLengthList
                else:
                i += 1
        else:
            for row in rows:
            if len(arcLength) > ' ':
                print arcLength
            else:
                print shapeLength
    del row, rows
ArcLength  is a string field with spaces, so the test will fail unless it converts the string to a number and tests for a space.  IN works even if there are no listed object (nothing is selected but no error occurs), a single item, or a list of items, so the else clause is not necessary.  = fails and produces an error if there is no listed objectID value or a list, so IN is all you need.
RichardFairhurst
The IN operatot is not a python expression.  It is an SQL expression and it is fine to use with all of the databases and the only efficient way to work with lists of values in SQL.  It is also fine to use with Python lists, since Python code that uses the IN expression will be found all over the Python forum by every advanced user of Python here.  So ignore that recommendation for both SQL and Python.  So use the IN operator as shown in my example or Jakes example (as corrected by me for the arcLength field test) and you will get the idea soon enough about what it does.
JamesSmith7
Richard,
Which statement accounts for the ARCLENGTH field being a string with spaces?  Because, if I use your example, I run into a RuntimeError: A column was specified that does not exist, in line 15.  for row in rows:, but the error is probably in line 14, the SearchCursor.
import arcpy
arcpy.AddMessage(lyr.name)
 myString = ",".join(sel_set)
 rows = arcpy.da.SearchCursor(lyr, ["OID@", "ARCLENGTH", "Shape_Length"], "OBJECTID IN (" + myString + ")")
 for row in rows:
  shapeLength = row.Shape_Length
  if len(arcLength) > 0:
   arcpy.AddMessage("ArcLength = " + arcLength)
  else:
   arcpy.AddMessage("ShapeLength = " + str(shapeLength))
  del row, rows
JamesSmith7
I am receiving an error in line 66, del row, rows.  The error code is an NameError: name row and rows are not defined.  How are they not defined?  If I comment the del row, rows statement out the script runs, but without errors or results.
import arcpy
   arcLengthList = []
   for row in rows:
    shapeLengthList.append(row.Shape_Length)
   i = 0
    if len(arcLengthList) > 0:
     print arcLengthList
    else:
    i += 1
    arcpy.AddMessage("Good")
  else:
   for row in rows:
   else:
 del row, rows
RichardFairhurst
I am receiving an error in line 66, del row, rows.  The error code is an NameError: name row and rows are not defined.  How are they not defined?  If I comment the del row, rows statement out the script runs.
import arcpy
   arcLengthList = []
   for row in rows:
   i = 0
     print arcLengthList
    else:
    i += 1
  else:
   for row in rows:
   else:
  del row, rows
Just indent the del row, rows one more time and that will fix that line.  It is at the wrong indent level.
JamesSmith7
I would have expected an indentation error, but not the name error.  Thanks.
