IED for python - code completion
1864
05-10-2012 12:42 PM
forestknutsen1
I have been using EasyEclipse for python, which overall has been working out. But the code completion does not work as it should when I type "arcpy.en" it should suggest "arcpy.env" as it does in the conversational mode inside of arcgis.
[ATTACH=CONFIG]14244[/ATTACH]
did I do some thing wrong when I configured eclipse? Or is there a better IDE to use?
BKuiper
I think most people are using PyScripter, which has Intellisense as well.
BKuiper
forestknutsen1
Thanks - only used it for a few minutes this AM; however, it is working much better then EasyEclipse for python.
DanPatterson_Retired
Pythonwin that comes on your installation CD is probably the standard, Pyscripter is much newer is isn't distributed with Arc but is nice, but lacks script folding which is a nice feature of Pythonwin
