I want to zonal statistics for multiple raster.
970
05-14-2013 05:54 PM
LEEjongseok
now, i use only single zonal statistics module.
but i want to multiple zonal tool.
# Import arcpy module
import arcpy, os
from arcpy import env
from arcpy.sa import *
# Check out any necessary licenses
arcpy.CheckOutExtension("spatial")
# Input data source
arcpy.env.workspace = "C:/py/07"
arcpy.env.scratchWorkspace = "C:/py/07"
ZoneData = "C:/py/FISHNET_4k_FeatureToPolygon.shp"
# Output File
OutputFolder = "C:/py/zonal"
# Loop through a list of files in the workspace
RasterFiles = arcpy.ListRasters()
print RasterFiles
print " "
# Local variables:
for filename in RasterFiles:
    print "Processing: {0}".format(filename)
    input_dir = arcpy.env.workspace
    inRaster1 = "C:/py/07/lai_0907_m"
    outRaster1 = os.path.join(OutputFolder,"z4_" + filename)
    # Process: Zonal Statistics
    saveRaster = arcpy.sa.ZonalStatistics(ZoneData, "ID", inRaster1, "MEAN", "DATA")
    saveRaster.save(outRaster1)
print "done"
but, i have 12 raster files.
and, i want to zonal at the one time..
please help me.
how can i do? i heard loop, but, i can use that..
raster file name. (lai_0901,lai_0902, ......, lai_0912)
Luke_Pinner
MVP Regular Contributor
Luke_Pinner
No need to post duplicates. Also please read: How to post Python code.
