I used survey123 and it was great tool.Something going wrong now I cant use the latest version of XLSF form and I am getting bellow message please help
2566
09-24-2020 02:27 PM
JumaKhudonazarov1
by Anonymous User
Not applicable
Hi Juma,
Can you please provide more details? e.g. what version of Survey123 Connect, are we re-publishing an existing survey, what changes have we made to the XLSForm?
Is it possible to provide the XLSForm?
Generally I would anticipate that this error is caused by invalid XLSForm configuration. Missing elements or overwritten formatting.
Cheers,
Chris
JumaKhudonazarov1
Hi Chris,
Thanks. I tried to download 3 times connect and didn't work. I have
attached screenshot of the message and XLSX form. Please help.
Best regards,
Juma
Dr_JumaKhudonazarov
Can anyone help what to do with this XLSForm  I try to downed  survey123 from Esri website and they are bugged  , can someone actually sort this out ?
by Anonymous User
Not applicable
Thanks Juma.
The issue is because you have three questions, with Names:
  1. example
  2. kartoshka
  3. example2
The 'instance_name' in the settings sheet is referencing a question with name 'example1'
  • concat('Label1: ',${example1},' Label2: ',${example2})
As 'example1' does not exist, it throws an error during construction.
Also just noticed you've posted this in Python. Please move the thread to the Survey123 community for more visibility.
Cheers,
Chris
