I'M GETTING THIS ERROR "TypeError: cannot concatenate 'str' and 'int' objects"
1525
07-02-2013 07:35 AM
OLANIYANOLAKUNLE
I was trying to construct the sql statement below to label a feature
lyr = arcpy.mapping.ListLayers(mxd, "Line_Clip")[0] for lblClass in lyr.labelClasses:     lblClass.SQLQuery = '"ParcelID"' + "=" + str(val) + "AND" + "Bearing" + ">" + 180 TypeError: cannot concatenate 'str' and 'int' objects
Please any help, thank you.
markdenil
To start, try casting the 180 to a str
str(180)
You might want to add some spaces in the string you are building
val = 100
'"ParcelID"' + "=" + str(val) + "AND" + "Bearing" + ">" + str(180)
yeilds
"ParcelID"=100ANDBearing>180
try
val = 100
'"ParcelID" = ' + str(val) + ' AND "Bearing" > ' + str(180)
which gives you
'"ParcelID" = 100 AND "Bearing" > 180'
LindseyWood
I believe it is your 180 value its an integer make the whole thing a variable like you would want it to look to sql then pass that to lblCalss.SQLQuery.
query = ' %s = %s AND Bearing > 180' %(ParcleID,val)
http://stackoverflow.com/questions/1225637/python-string-formatting
I like the c formatting way but there are many that would make it easier.
or just str(180)
markdenil
str(180)
val = 100
yeilds
try
val = 100
which gives you
RhettZufelt
MVP Notable Contributor
This works.
lblClass.SQLQuery = '"ParcelID"' + "=" + str(val) + " AND " + '"Bearing"' + " > " + "180"
R_
OLANIYANOLAKUNLE
Thanks Y'All mdenil, lmwood & rzufelt you guys are the BEST.....
