>>> import arcpy >>> import sys >>> import os >>> arcpy.CreateArcSDEConnectionFile_management("C:/connectionFiles","connect.sde","MKT/otc","sde:sqlserver:MKT/p10","BDP10TN_SIG","OPERATING_SYSTEM_AUTH","dbo.DEFAULT","DO_NOT_SAVE_VERSION")
what if you want to do it without an sde database connection?
say I am setting this up to be activated from arcpad instead
