How to work with GDAL on ArcGIS Server machine with ArcGIS for Desktop?
751
10-23-2013 09:05 AM
LUKASZBLASZCZYK
ArcGIS Desktop 10.1 works with Python27 32 bit and with GDAL 32 bit and Python bindings. I created script that works in the PyScirpter and in ArcGIS for Desktop.  But in that case my script by default read systems variables and uses GDAL 32 bit. When I published the GP Service from the script, run it by REST I get this error:
esriJobMessageTypeError:
Traceback (most recent call last): File "C:\arcgisserver\directories\arcgissystem\arcgisinput\Analyst\Analize.GPServer\extracted\v101\analize\ZonalStatsPerryGeoServer.py", line 14, in from osgeo import gdal File "C:\Python27\ArcGISx6410.1\lib\site-packages\osgeo\__init__.py", line 21, in _gdal = swig_import_helper() File "C:\Python27\ArcGISx6410.1\lib\site-packages\osgeo\__init__.py", line 17, in swig_import_helper _mod = imp.load_module('_gdal', fp, pathname, description) ImportError: DLL load failed: Nie mo?na odnale??? okre??lonego modu??u.
I installed both versions of GDAL (32 i 64 bit) with Python bindings.
How to conifgure ArcGIS for Server 10.1 to work with proper version of GDAL?
