How to use Field Mappings
7020
09-14-2015 11:48 AM
mpboyle
Honored Contributor
I'm trying to understand how to use the FieldMappings object in arcpy, but am getting confused.
I have two tables, an input table and a target table.  I'm trying to use the Append tool to load data from the input table into the target table.  I have two fields within each table that need to be mapped.
Input
NEAR_FID
BUFF_DIST
Target
WellOID
Distance
Mapping should be:
NEAR_FID = WellOID
BUFF_DIST = Distance
Any suggestions on how to map these fields using the FieldMappings object would be greatly appreciated!
Tags (1)
WesMiller
Here is how I'm using field mappings for my street index creator hope this helps
http://desktop.arcgis.com/en/desktop/latest/analyze/arcpy-classes/fieldmappings.htm
# Create a new fieldmappings and add the two input feature classes.
fieldmappings = arcpy.FieldMappings()
fieldmappings.addTable(DissolvedStreets)
fieldmappings.addTable(InputGrid)
jField = fieldmappings.findFieldMapIndex(gridField)
fieldmap = fieldmappings.getFieldMap(jField)
fieldmap.mergeRule = "join"
fieldmap.joinDelimiter = ","
fld_length = fieldmap.outputField
fld_length.length = 255
fieldmap.outputField = fld_length
arcpy.AddMessage(str(fieldmap.outputField.length))
fieldmappings.replaceFieldMap(jField, fieldmap)
# Process: Spatial Join
arcpy.SpatialJoin_analysis(DissolvedStreets, InputGrid, outfc, "#", "#", fieldmappings)
MahtabAlam1
Following might help a bit:
# define new mappings and load default from fc or table
fieldmappings.addTable(yourFCorTable)
# now you define the ouput fields
fieldmap1 = fieldmappings.getFieldMap(1)
outField1 = fieldmap.outputField
outField1.name = "WellOID"
outField1.aliasName = "WellOID"
fieldmap1.outputField = outField1
fieldmap2 = fieldmappings.getFieldMap(2)
outField2 = fieldmap2.outputField
outField2.name = "Distance"
outField2.aliasName = "Distance"
fieldmap2.outputField = outField2
# now you can use your field mappings
