How to to get current legend column count using arcpy?
3587
11-03-2015 12:44 PM
SurendranNeelakantan
Hi
Is there anyway to get current legend column count using arcpy? like legegend.columncount   OR legend.getcolumncount ? I couldn't see these properties in documentation.
I am trying to increment  column count conditionally using  legend.adjustColumnCount
Thank you
LukeSturtevant
If I'm understanding your question you are looking to get a total count of layers represented in the legend? If so then you could use:
mxd = arcpy.mapping.MapDocument("Current")
df = mxd.activeDataFrame
legendCount = len(arcpy.mapping.ListLayoutElements(mxd, "LEGEND_ELEMENT", "Legend")[0].items)
I   want to know how many columns in the  legend element.  Not how many items in the legend.
I hope It is clear now.
DarrenWiens2
Can you explain why incrementing adjustColumnCount doesn't work? It seems like you should be able to:
1.) make any changes to your legend
2.) record the current (original) legend elementWidth
3.) increment the number of columns using adjustColumnCount
4.) when the incremented legend elementWidth = the original legend elementWidth, you know the number of columns
WesMiller
The default for column count is 1 if your trying to increment a legend simply start or reset the legend to 1
LegendElement—Help | ArcGIS for Desktop
