How to stop a command or prompt in Python?
66153
10
03-31-2011 09:25 AM
DaveCouture
I'm using ArcGIS 10 and I'm practicing a few scripts with Python.  What command should I use, if I want to exit a commnad, or a function?  I'm always stuck with 3 dots (secondary prompt).  How do I stop it?
I've tried:
sys.exit()
sys.exit(0)
quit()
RhettZufelt
MVP Notable Contributor
It almost sounds to me like you have a corrupt python install.
In python.exe, IDE, or the python window in ArcMap, I can not repeat.  The only time I can get the ... is if I do a multiline entry ( IE, if this == "that":) or nested code.
an import statement should never be "seen" as a multiline entry or nested code.
Curious what happens if you type this:
>>>print "testing"
Do you get:
>>>print "testing"
testing
or do you get:
>>>print "testing"
If you get the latter, I would try a remove/re-install of your python.
R_
