How to solve this python question? I can't figure out at all...this one is stubborn
1513
02-28-2014 03:09 PM
PeterPete
def average_word_length(text):
    """ (list of str) -> float
    Precondition: text is non-empty. Each str in text ends with \n and at
    least one str in text contains more than just \n.
    Return the average length of all words in text. Surrounding punctuation
    is not counted as part of the words.
    >>> text = ['James Fennimore Cooper\n', 'Peter, Paul and Mary\n']
    >>> average_word_length(text)
    5.142857142857143
CodyScott
    5.142857142857143
I would approach it by first removing the '\n' from the string and removing the punctuation from the string.
After that, split the string by looking for the spaces in it, which should provide you with a tuple of each word in the string.
Then, loop each word getting its length and calculate an average from each word.
Here is a guess at the code below. I haven't tested this so who knows if the syntax is correct...
Also look here: http://stackoverflow.com/questions/12761510/python-how-can-i-calculate-the-average-word-length-in-a-...
Best of luck!
for scen in text:
    string = scen.replace('\n','')
    #this would be any punctuation you want to replace
    string = string.replace("'","")
    #confirm syntax
    string = string.split(' ')
    wordcount = len(string)
    wordlen = 0
    for word in string:
        tmplen = 0
        for letter in word:
            tmplen += 1
        wordlen += tmplen
    avglen = (wordcount/wordlen)
    print avglen
CodyScott
Best of luck!
for scen in text:
    #confirm syntax
    wordlen = 0
    for word in string:
        tmplen = 0
        for letter in word:
            tmplen += 1
        wordlen += tmplen
    print avglen
Oh, if you had a ton of punctuation you wanted to get rid of everytime, write a function to parse the text and return the "stripped" version of your text
XanderBakker
Esri Esteemed Contributor
You could use this:
    ''' Return the average length of all words in text. Do not
    include surrounding punctuation in words.
    text is a non-empty list of strings each ending in \n.
    At least one line in text contains a word.'''
    words = text.split()
    for word in words:
            average=sum(float(len(word)) for word in words)/float(len(words))
    return average
Sounds a lot like this post:
http://forums.arcgis.com/threads/103785-Hey-I-was-wondering-about-this-function-problem-for-a-while
... on comparing signatures ...
Kind regards,
Xander
