How to remove all topology layers from a feature dataset
2337
01-29-2020 06:05 AM
JoseSanchez
Hello everyone,
I would like to build a function in python that removes all topology layers from a  feature dataset.
How can I check if a feature dataset has topology with arcpy,  and also how can identify topology layers to delete them.
Thanks
JoeBorgione
Have you taken a look here:  Common topology tasks—Topologies | ArcGIS Desktop  ?
That should just about do it....
JoseSanchez
Thank you.
I just hard coded the name of the Topology FC and it works
here is the saple I used to test:
# Import arcpy module
import arcpy
# Local variables:
MyFC_Topology = "...\\FGDB.gdb\\MyFD\\MyFC_Topology"
# Process: Delete
arcpy.Delete_management(MyFC_Topology, "Topology")
JoeBorgione
I took the liberty of using the Syntax highlighter to make your code more readable. (here is one of the many posts that describe using it:  Posting code with Syntax Highlighting on GeoNet )
import arcpy
# Local variables:
# Process: Delete
It appears you are on you way...
