How to Properly Use env.scratchGDB to Gaurantee Write Access
1586
04-29-2013 06:37 AM
MarcCusumano
In scripting business processes it is coming up again and again where I need an intermediate workspace to write data. I am trying to copy a table to the scratch workspace but it is placing the table into a dbf in the folder where the scratchGDB is located. Here is what I have:
import arcpy, arceditor, logging, datetime, os, smtplib
from arcpy import env
InputPrefix = "Database Connections\\Sun130 - 5151.sde\\"
tblImplsblRd = InputPrefix + "GIS_INTERFACE.SAP_IMPLAUSIBLE_READS"
lclImplsblRd = env.scratchGDB + "SAP_IMPLAUSIBLE_READS"
def copyRows(src, trgt, cfg):
    try:
        arcpy.CopyRows_management(src, trgt, cfg)
        logging.info(": Copied %s to %s" %(src, trgt))
    except Exception as e:
        print e
        logging.error(": %s" %(e))
        msgTxtErr = msgTxtErr + "\n" + "* " + str(e)
        errValue = 1
copyRows(tblImplsblRd, lclImplsblRd, "")
print "done"
When I run this from a script exported from ModelBuilder it places the table into the temporary gdb:
# -*- coding: utf-8 -*-
# temp.py
# Created on: 2013-04-29 10:29:12.00000
#   (generated by ArcGIS/ModelBuilder)
# Description:
# Import arcpy module
import arcpy
# Local variables:
GIS_INTERFACE_SAP_IMPLAUSIBLE_READS = "Database Connections\\Sun130 - 5151.sde\\GIS_INTERFACE.SAP_IMPLAUSIBLE_READS"
SAP_IMPLAUSIBLE_READS = "C:\\Users\\TDMC0\\AppData\\Local\\Temp\\scratch.gdb\\SAP_IMPLAUSIBLE_READS"
# Process: Copy Rows
arcpy.CopyRows_management(GIS_INTERFACE_SAP_IMPLAUSIBLE_READS, SAP_IMPLAUSIBLE_READS, "")
However if the path to the scratch GDB is hard-coded I will lose the ability to have a gauranteed space to write data. Would appreciate help getting this working correctly.
ChrisSnyder
Honored Contributor
Looks like you just need to include a path seperator (i.e. "\\")
So instead of:
use one of these:
lclImplsblRd = env.scratchGDB + "\\SAP_IMPLAUSIBLE_READS"
lclImplsblRd = os.path.join(env.scratchGDB, "SAP_IMPLAUSIBLE_READS")
lclImplsblRd = env.scratchGDB + os.path.sep + "SAP_IMPLAUSIBLE_READS"
ChrisSnyder
Honored Contributor
BTW: You might find the "in_memory" workspace another (maybe better) option for what you need
http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#//002w0000005s000000
MarcCusumano
Thanks I added the "\\" but am still getting errors due to schema locks. I was under the impression that could not happen (hence the whole point of the scratchGDB environment). If there is something else I am doing wrong please let me know.
I will implement the in-memory workspace after testing is complete but in the development stage I need to see the intermediate tables structures.
ChrisSnyder
Honored Contributor
schema locks
Surefire way to clear schema locks:
If you are or ever have looked at the contents of the scratch workspace with your current ArcMap session, close ArcMap and reopen it.
If you are or ever have looked at the contents of the scratch workspace with your current ArcCatalog session, browse to another workspace/directory and hit F5.
If you are or ever have looked at the contents of the scratch workspace with Python via arcpy, close your Python IDE, and reopen it.
