how to get the hightlighted layers in TOC ?
1376
11-07-2023 09:47 PM
pyfans
How to get  the selected layers in the TOC (i.e. clicked via the mouse and is now highlighted)  with arcpy? thank you.
Tags (3)
DanPatterson
there is no arcpy functionality to do this
... sort of retired...
StaticK
MVP Alum
You could check them (uncheck the others you don't want) and then use the lyr.visible property to separate them.
aprx = arcpy.mp.ArcGISProject(r'C:\.aprx')
m = aprx.listMaps("Map")[0]
checked_layers = [lyr for lyr in m.listLayers() if lyr.visible]
#for lyr in m.listLayers():
#    if lyr.visible:
#        arcpy.AddMessage(f"{lyr.name} is selected.")
