How to get coordinates from next row?
1123
07-24-2012 12:01 PM
NickJacob
I recently used the CalculateEndTime (http://goo.gl/mJqjG) tool and wanted to attempt something similar but with coordinates.  More specifically,  I'm trying to figure out a way to use the field calculator to get x and y values from the next row.  Technically, the code below works, but it's definitely not pretty... or fast!  Any thoughts or suggestions on how to do this better?
[ATTACH=CONFIG]16390[/ATTACH]
Expression:
calculate_next_y(!OID!)
Code Block:
def calculate_next_y(my_field):
    oid_no = my_field
    rows = arcpy.SearchCursor(r"in_memory\points_mem", "", "", "", "OID; Time_Local")
    for row in rows:
        if row.getValue("OID") == oid_no:
            try:
                next_row = rows.next()
                new_y = next_row.getValue("Latitude")
                break
            except:
                new_y = row.getValue("Latitude")
    return new_y
Thanks!
