How to find a minimum angle in polygon?
3367
08-16-2019 12:23 AM
KK2
Is it possible to calculate the minimum angle in a polygon? I have several polygons that have sharp edges, as in the attached picture, and I would like to indicate them automatically. For example, can I create a column in the attribute table with minimum angle values in a polygon?
JohannesBierer
To find sharp edges you can convert the polygons to raster, boundary clean, reconvert to polygon, buffer with a appropriate distance and clip?
DanPatterson_Retired
PS, you picture is for polygons, so moving to Python since this isn't a Spatial Analyst thread.
Feed polygon shapes to 'angles_poly'.  Numpy required
Polygons can be converted to numpy arrays using.  This is the implementation for a whole featureclass converted to a numpy object array
def poly2array(polys):
    """Convert polyline or polygon shapes to arrays for use in the Geo class.
    Parameters
    polys : tuple, list
        Polyline or polygons in a list/tuple
    def _p2p_(poly):
        """Convert a single ``poly`` shape to numpy arrays or object"""
        sub = []
        for arr in poly:
            pnts = [[pt.X, pt.Y] if pt else null_pnt for pt in arr]
            sub.append(np.asarray(pnts))
        return sub
    if not isinstance(polys, (list, tuple)):
        polys = [polys]
    out = []
    for poly in polys:
        out.append(_p2p_(poly))
    return out‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
In a script, a search cursor can be used to get a polygon, and it can be converted using _p2p_ in the above..
    def _p2p_(poly):
        sub = []
        for arr in poly:
        return sub‍‍‍‍‍‍‍
def angles_poly(a=None, inside=True, in_deg=True):
    """Sequential 3 point angles from a poly* shape
    Parameters
    a : array
        an array of points, derived from a polygon/polyline geometry
    inside : boolean
        determine inside angles, outside if False
    in_deg : boolean
        convert to degrees from radians
    Sample data: the letter C
    >>> a = np.array([[ 0, 0], [ 0, 100], [100, 100], [100,  80],
                      [ 20,  80], [ 20, 20], [100, 20], [100, 0], [ 0, 0]])
    >>> angles_poly(a)  # array([ 90.,  90.,  90., 270., 270.,  90.,  90.])
    if len(a) < 2:
        return None
    if len(a) == 2:
        ba = a[1] - a[0]
        return np.arctan2(*ba[::-1])
    dx, dy = a[0] - a[-1]
    if np.allclose(dx, dy):  # closed loop
        a = a[:-1]
    a0 = np.roll(a, -1, 0)
    a1 = a
    a2 = np.roll(a, 1, 0)
    ba = a1 - a0
    bc = a1 - a2
    cr = np.cross(ba, bc)
    dt = np.einsum('ij,ij->i', ba, bc)
    ang = np.arctan2(cr, dt)
    two_pi = np.pi*2.
    if inside:
        ang = np.where(ang < 0, ang + two_pi, ang)
    else:
        ang = np.where(ang > 0, two_pi - ang, ang)
    if in_deg:
        angles = np.degrees(ang)
    return angles
# ---- demo --- a polygon "C"
import numpy as np
angles = angles_poly(a, inside=True, in_deg=True)
min(angles)
90.0
angles
array([270., 270., 270., 270.,  90.,  90., 270., 270.])
So the code would entail
open a search cursor
convert each shape to an array using _p2p_
call angles_poly
take its minimum
KK2
Thank you for the answer. I have found an easy solution in QGIS: Vector > Geometry Tools >Check Geometries > Minimum angle between segments (deg). After its finished you can export a point shapefile indicating places where polygons have lower angle than a specified threshold, and the ID of the original polygons.
