How to export large series polygons with repited ones
956
09-04-2012 03:47 AM
AlexanderMakarov
hello
I would like to ask a question:
There is a map with some polygons A (they are numbered). There is also rectangular grid of polygons of type B (they are also numbered). Question: how do export to PDF polygons A by polygons B?
My varant of solution: to clarify the sequence of polygons in that should get (I figured out how to do it), and then run a script that export in this sequence. Can you suggest how code of this script should look like, provided that some of the polygons B to be, of course, repeated and the series is quite large, about 400-500 ones.
Or maybe you can provide me another variant of solution.
Thanks in advance
ChristopherThompson
Can you help clarify your question?  I think you want to be able to export a PDF showing all polygons from A that are with in each of the polygons in B.  Is that correct?
DarrenWiens2
Have you looked into Data Driven Pages (ArcGIS 10+)? If you're using ArcGIS 9.3 or lower, check out DS Mapbook. Either way, it allows you to output PDF pages showing data (your polygons) by an index layer (your grid).
