How to delete the entire legend (not just the elements) using Arcpy
4336
06-25-2013 12:38 PM
ChrisJudd1
I have looked everywhere in the API to try to find a way to delete the entire legend from a dataframe using Arcpy, but I have not been able to find the correct method.  Could someone point me in the right direction?
DavidAllen
arcpy.mapping doesn't let you add or subtract elements from your layout. The help files suggest that if you have an element that you don't wish to display on the output, change the location of the element to be off the page using the .elementPositionX property.
DavidAllen
ChrisJudd1
Worked like a charm, thank you!  I set the set the legend's elementPositionX to -5000, like below and no more legend:
elementPositionX = -5000
Yaron_YosefCohen
Chris, can you please write the all script-this attached script don't work ?
