How to delete parts from geometry object?
1750
05-11-2021 03:36 AM
TomGeo
I have a FeatureClass of polygons. A good part of those polygons have holes and I would like to get rid of them if they are below a certain size.
I managed to get to the parts and calculate their size. I also thought I delete unwanted parts... however, when writing them out there is no difference. I do not really know if my error is located in the part of deleting parts or at the point where I try to write them to disk.
arcpy.management.CreateFeatureclass(fc_path, 'clear', 'POLYGON', spatial_reference=sr)
geoms = arcpy.management.CopyFeatures(simplified, arcpy.Geometry())
with arcpy.da.InsertCursor(without_holes, 'SHAPE@') as iCursor:
    for geom in geoms:
        partnum = geom.partCount
        parts = geom.getPart()
        if partnum > 1:
            lst_rm = []
            for n in range(1, partnum):
                part = geom.getPart(n)
                part_geom = arcpy.Polygon(part, sr)
                if part_geom.area > 50.0:
                    lst_rm.append(n)
            lst_rm.sort(reverse=True)
            for i in lst_rm:
                parts.remove(i)
        polygon = arcpy.Polygon(parts)
        row = (polygon,)
        iCursor.insertRow(row)
- We are living in the 21st century.
GIS moved on and nobody needs a format consisting out of at least three files! No, nobody needs shapefiles, not even for the sake of an exchange format. Folks, use GeoPackage to exchange data with other GIS!
DanPatterson
advanced license required
Eliminate Polygon Part (Data Management)—ArcGIS Pro | Documentation
And from @JoshuaBixby
ArcPy: Remove Holes in Polygons (github.com)
You can examine his gist code.
... sort of retired...
