How to Concatenate Fields
10935
27
02-06-2013 09:52 AM
CraigMcDade
I have an attribute table with approx 1000 records. There are two Fields I care about: Name and Pg_Number (see attached pic)
I would like to consolidate the fields so that I received an output or a new field that combines the Pg_Number field based on the Name Field
Ex.
In my head its something like:
if [Name] = "Orange Lake" then [Pg_Number] = 5, 6, 7, 8, 9, 10...
if [Name] = "Green Lake" then [Pg_Number] = 11, 12, 13, 14, 15..."
and so on...
I haven't had much experience with Python but I'm trying to build a model/script and I'm getting stuck on how to do this field calc/consolidation.
Any help would be appreciated.[ATTACH=CONFIG]21511[/ATTACH]
CraigMcDade
1 step closer. Now its telling me:
Runtime error
  File "<string>", line 19, in <module>
RuntimeError: Cannot find field 'NAME'
Does my new table need to have these field names or will it generate them automatically?
MathewCoyle
Honored Contributor
You need to create your target table with the field names and properties you want. You could modify the insertCursor object creation to have different field names if you'd like, but yes they will have to created already.
CraigMcDade
I figured as much and created them as indicated in the code. Same error.
MathewCoyle
Honored Contributor
Post a copy of the table you created.
CraigMcDade
I've attached it. Thanks again.
MathewCoyle
Honored Contributor
Not sure why you would get that error. Are you sure 50 characters is long enough? I think you would see a different error if that were the issue though...
Actually I think I may have missed the last bracket in the last line I posted.
insertCursor.insertRow((key, ', '.join(str(item) for item in val)))
If that modification nets the same error can you post the code you are running?
CraigMcDade
The NAME field doesn't need to fit that many characters, The Pg_Number field needs to be long, I've adjusted it to its maximum size (which is apparently only 254 characters?) However, one of the NAME fields has 74 different page numbers plus the ", " so its maximum size should be set to 370
The code results in the same error, the full code I'm running is:
import os
import arcpy
table = r"c:\users\craig.mcdade\GridforPython.dbf" # source_table
new_table = r"table.dbf" # new table name + extension only
tempTable = r"\\in_memory\temp_table"
outPath = r"c:\users\craig.mcdade" # path to output location on disk
keyField = 'NAME'
valField = 'Pg_Number'
tableDict = {}
arcpy.MakeTableView_management(table, tempTable)
with arcpy.da.SearchCursor(tempTable, [keyField, valField]) as cursor:
    for row in cursor:
        tableDict.setdefault(row[0], []).append(row[1])
insertCursor = arcpy.da.InsertCursor(os.path.join(outPath, new_table), [keyField, valField])
for key, val in tableDict.iteritems():
CraigMcDade
I made the following change to the code and it is working now:
Replaced:
with:
with arcpy.da.SearchCursor(table, [keyField, valField]) as cursor:
Thanks for all your help! Now I just need to figure out how to create the field long enough so that all results are populated.
