How to change the default Python environment in ArcGIS Pro
3902
10-15-2024 05:40 PM
AbuBadruddin1
I am using ArcGIS Pro 3.3.3. Running a script is giving me the following message along with many other lines :
The version of the binaries in the active Python environment do
not match the version of the binaries of the ArcGIS Pro application.
Active environment version : 2.5
arcgispro-py3 environment version : 3.3
I open the IDLE file from the Python Command prompt & it shows the Python version of 3.11.8. However, right clicking & opening the script file with IDLE (ArcGIS Pro) shows the Python version of 3.6.9.
My question is how to change the Active environment in ArcGIS Pro to Python 3.11.8. I am sure that will solve the problem of mismatch!
Tags (1)
DanPatterson
MVP Esteemed Contributor
DanPatterson
from the help files
Activate an environment—ArcGIS Pro | Documentation
... sort of retired...
