How to apply attribute table settings (fields visibility and format) from one layer to another using arcpy?
1329
5
09-08-2025 02:48 AM
Sfortunatamente
I have 40 layers with the same table schema and I need to apply symbology and table settings from another layer. I have a template layer and applying symbology works as expected.
Is it possible to apply fields visibility and formats as well?
I can see pasteProperties (source_layer, {layer_paste_properties}) method but when applying in on a layer object I get the following error: AttributeError: 'Layer' object has no attribute 'pasteProperties'
L = map.addDataFromPath(r"..\Address.lyrx")
for lyr in map.listLayers():
    print(lyr.name)
    lyr.pasteProperties(L, layer_paste_properties="FIELD_PROPERTIES")
DanPatterson
MVP Esteemed Contributor
Layer—ArcGIS Pro | Documentation
you should check if it is a featurelayer before trying to try to pastProperties
isFeatureLayer
(Read Only)
Returns True if a layer is a feature layer.
... sort of retired...
TonyAlmeida
MVP Regular Contributor
Try this,
import arcpy
# Load the template layer
template_layer_path = r"..\Address.lyrx"
template_layer = arcpy.mp.LayerFile(template_layer_path).listLayers()[0]
# Get your map
aprx = arcpy.mp.ArcGISProject("CURRENT")
map = aprx.listMaps("Your Map Name")[0]
# Apply symbology + field properties
    if lyr.isFeatureLayer:
        print(f"Updating {lyr.name}...")
        arcpy.management.UpdateLayer(lyr, template_layer, True)  # True = keep data source
        print(f"Completed: {lyr.name}")
print("All layers updated successfully!")
Sfortunatamente
Didn't work..
AttributeError: module 'arcpy.management' has no attribute 'UpdateLayer'
TonyAlmeida
try
# Use ApplySymbologyFromLayer
        arcpy.ApplySymbologyFromLayer_management(lyr, template_layer)
HaydenWelch
I'd just use the CIM definition object, since all these properties can be set directly using dictionaries/CIM objects:
from typing import Any
from arcpy.management import MakeFeatureLayer
from arcpy.cim.CIMVectorLayers import CIMFeatureLayer
from arcpy.mp import ArcGISProject
from arcpy._mp import Layer, Map
def get_state(lyr: Layer) -> dict[str, Any]:
    layer_cim: CIMFeatureLayer = lyr.getDefinition('V3')
    states_to_save = [
        'snappable',
        'selectable',
        'visibility',
        'expanded',
        'labelVisibility',
    return {k:v for k, v in layer_cim.__dict__ if k in states_to_save}
def apply_state(lyr: Layer, state: dict[str, Any]) -> None:
    if not lyr.isFeatureLayer:
        return
    layer_cim.__dict__.update(state)
    lyr.setDefinition(layer_cim)
The first function will pull states from a layer and the second will apply those states to a layer. In your case, you can put these in a loop for the map:
def update_map_layers(mp: Map, state: dict[str, Any]) -> None:
    for layer in filter(lambda m: m.isFeatureLayer, mp.listLayers()):
        apply_state(layer, state)
def main():
    template_layer = MakeFeatureLayer(r'<path/to/template>.lyrx')[0]
    state = get_state(template_layer)
    project = ArcGISProject('<path/to/project>.aprx || CURRENT')
    mp = project.listMaps('<map_name>')[0]
    update_map_layers(mp, state)
if __name__ == '__main__':
    main()
