Hi all,
I want to add a text zone (or an sql expression zone) to add text or sql statement when I lunch my tool.
I tried to do so by using string or sql expression parameter with multi-values. the problem is that I can not write any text.
I noticed also that there is a button at the right of Select all/Unselect all but it is all the time not activated
Any help please??
Thanks in advance
Hi Dan
No, it did not work. When I make it derived, it is like an output. But even with derived, I could not link it to my feature layer from Obtained from property
Strange... your featureclass does have fields in it and it is an input parameter, so perhaps you have to add a field parameter in there derived from the featureclass.. The only thing I can suggest now, is create your workflow using tools from arctoolbox solely, then examine the results in the Results window to see the linkages.
