How I get all names of a Style File Markersymbols with ArcPY
4190
8
02-02-2017 09:09 AM
UlfSalecker
I build a new true Type Font and I will check the names
JoshuaBixby
MVP Esteemed Contributor
It isn't your version, I just ran the following on an ArcGIS 10.1 (build 3143) install:
>>> import os
>>> style_dir = os.path.join(arcpy.GetInstallInfo()['InstallDir'], 'Styles')
>>> style_file = os.path.join(style_dir, 'ESRI.style')
>>> style_folder = 'Marker Symbols'
>>> styles = arcpy.mapping.ListStyleItems(style_file, style_folder)
>>> for style in styles:
...   print style.itemName
Circle 1
Square 1
Triangle 1
Rnd Square 6
Rnd Square 7
Dam Lock
Please review the documentation.  The style folder name you need to pass isn't a directory on the file system, it is the name of the style folder in the style file itself that you want to get information about.  In this case, with marker symbols, it needs to be "Marker Symbols".  If you were interested in colors, it would be "Colors".
JoshuaBixby
Does this work for you:
style_file = # path to style file
style_folder = "Marker Symbols"
UlfSalecker
Thanks for your answer. I work with ArcGIS V10.1 and I created the following Python Skript:
import arcpy
style_file = "C:\ArcGIS\Styles"
style_folder = "MVV_Netrion_Bestand_Gas.style"
I get the following errors:
File "C:\ArcGIS\python\read_style.py", line 6, in <module>
File "C:\Program Files (x86)\ArcGIS\Desktop10.1\arcpy\arcpy\mapping.py", line
1599, in ListStyleItems
return convertArcObjectToPythonObject(arcgisscripting._listStyleItems(*gp_fi
xargs([style_file_path, style_folder_name, wildcard], True, False)))
ValueError: StyleGalleryObject: Input value is not valid
Whats the problem?
NeilAyres
This looks the wrong way round to me.
UlfSalecker
oh sorry, but it doesn work. Ich think its the wrong ArcPY Version. I work with ArcGIS V10.1.
# C:\Python27\ArcGIS10.1\python.exe C:\ArcGIS\python\read_style.py
import arcpy
style_folder = "C:\ArcGIS\Styles"
style_file = "MVV_Netrion_Bestand_Gas.style"
C:\Users\u2267>C:\Python27\ArcGIS10.1\python.exe C:\ArcGIS\python\read_style.py
File "C:\ArcGIS\python\read_style.py", line 7, in <module>
return convertArcObjectToPythonObject(arcgisscripting._listStyleItems(*gp_fixargs([style_file_path, style_folder_name, wildcard], True, False)))
IOError
NeilAyres
style_file still needs to be a full path to the style file, including the filename itself.
ListStyleItems—Help | ArcGIS for Desktop
JoshuaBixby
>>> import os
Circle 1
Square 1
Triangle 1
Rnd Square 6
Rnd Square 7
Dam Lock
UlfSalecker
It's work. thanks a lot Joshua
JoshuaBixby
Glad you got it working.  In order for others to know this thread is answered, please mark a response as correct.
