How do you import an SQL query/view into arcgis
6104
12
10-27-2014 07:34 AM
deleted-user-Pi5x1UjkS2PY
Have a view in SQL that I want to bring into ArcGIS using python.  It is part of a process of a longer python script.  how can I do this using python.
In 9.3 I used my ODBC connection  "AR"  to do this and then brought in my file "GISWEB.VW_MCYWEB" as an XY Event and then exported it as a shapefile with a coordinate system of WebMercator so that I could use it in my web maps.
I've tried several things but nothing is working for me at the moment.  I'm sure this is simple but I'm not see how to do this.
I thought maybe this would work.
import arcpy
import win32api, win32con
import sys
import pyodbc
from arcpy import env
def defAddSQLTable_CreateShapefile():
    ### Works Makes a list of all tables in SQL Database for that DSN Connection ###
    cnxn = pyodbc.connect("DSN=AR")
arcpy.env.workspace= 'C:/temp'
in_Table = "AR.GISWEB.VW_MCYWEB"
y_coords = "Longitude"
x_coords = "Latitude"
out_layer = "Stores"
arcpy.env.overwriteOutput = 'true'
arcpy.MakeXYEventLayer_management(in_Table, x_coords, y_coords, out_layer)
DanPatterson_Retired
Numpy lesson part 2....
If you are producing an array from a list of lists, you can run into some problems...
>>> import numpy as np
>>> data_list = [[0,'Walmart',-75.0,45.0],[1,'Costco',-75.5,45.1],[2,'Best Buy',-75.1,45.2],[3,'Shoppers',-75.2,45.3]]
>>> dtype = np.dtype([('ID','<i4'),('Store','|S25'),('Long','<f8'),('Lat','<f8')])
>>> np_array = np.array(data_list,dtype)
  File "<interactive input>", line 1, in <module>
TypeError: expected a readable buffer object
you can correct for this by using a generator to convert the list of lists to a list of tuples...and life is good
>>> data = [ tuple(row) for row in data_list]
>>> data
[(0, 'Walmart', -75.0, 45.0), (1, 'Costco', -75.5, 45.1), (2, 'Best Buy', -75.1, 45.2), (3, 'Shoppers', -75.2, 45.3)]
>>> np_array = np.array(data,dtype)
>>> np_array
array([(0, 'Walmart', -75.0, 45.0), (1, 'Costco', -75.5, 45.1),
      (2, 'Best Buy', -75.1, 45.2), (3, 'Shoppers', -75.2, 45.3)],
      dtype=[('ID', '<i4'), ('Store', 'S25'), ('Long', '<f8'), ('Lat', '<f8')])
The stores in no way sponsor this thread...
Changed to this and it works like a charm
datarray.append(tuple(row))
One last question.  I need to be able to add the spatial reference of webmercator to it.  I know you do it somehow like this.
Just not sure what to put in for webmercator?
SR = arcpy.Describe("C:/data/texas.gdb/fd").spatialReference
stealing from the help files
# Export the numpy array to a feature class using the XY field to
#  represent the output point feature
arcpy.da.NumPyArrayToFeatureClass(array, outFC, ['XY'], SR)
As long as you have a valid spatial reference, then you add it as SR when creating the output
